Author Topic: Bass Upgrade RNS510  (Read 5357 times)
Offline Greenman
  • Life is not a straight line!
Bass Upgrade RNS510
« on: October 24, 2015, 07:50:56 pm »
I want more low down bass for my 06 GTI with RNS510.
The standard system is punchey but not very bassy at the low end.
Can i simply add an additional amp for sub and upgraded front speakers or is it best to upgrade back speakers and amp them?
Does anyone know the size of the speakers in the front doors and in the rear?
TIA.
Steel Grey 2006 Mk5 GTI - R-TECH Stage 1 (268bhp/334ftlb) - BCS Cat Back - Pre-Cat Delete - Carbonio Panel Filter - Rev G DV - 18" BBS CH - Leather - RNS510 - Colour Coded Bumpers and Skirts - ED30 Front Splitter - Eibach Sportlines - Open Fog Grilles - Wind Deflectors.
Offline loop
  • -Given: 26
Re: Bass Upgrade RNS510
« Reply #1 on: October 24, 2015, 08:29:29 pm »
I wouldn't bother amping  the rear speakers just upgrade and amp the fronts then add a sub if needed after. I am about to do all this myself, have a new set of front speakers and an amp on the way, but unlikely I will get a sub.
‘05 GT, Retrofits: RNS 510 DAB+, R32 Highline Cluster, R32 MFSW, Mk6 Reversing Camera, 7P6 Bluetooth, TPMS, Cruise Control, VW MDI, Chrome switches, Blaupunkt THA 475 amp.
Offline Greenman
« Reply #2 on: October 24, 2015, 08:37:48 pm »
I've heard the lack of low bass is due to the doors being badly insulated.
Hence the reason i was thinking of going sub route, or back speaker upgrade.
Any thoughts?
Offline loop
  • -Given: 26
« Reply #3 on: October 24, 2015, 08:51:17 pm »
I've read somewhere that there's something in the RNS 510 that limits the output of the speakers (could be wrong). The problem with the front woofers is their position in the doors which is why they added a midrange speaker to get better sound separation. I would add silent coat or similar around the speakers to reduce vibrations and sound loss through the doors. The
Sound field is meant to come from in front of you which is why many don't bother with rears but I prefer having them for a surround effect even if just keeping the OEMs in. I don't know much about subs but there are enclosures you can buy so they fit in one side of the boot.
« Reply #4 on: October 24, 2015, 09:01:55 pm »
To get low bass you could add a amp but you need an adapter cable with rca for your h/u but if that's the route your going  change the header unit to after market one..I have just the fronts connected and amp and a discreet sub box look through my build thread
Offline Greenman
« Reply #5 on: October 24, 2015, 11:02:19 pm »
Do you get any vibration through the fronts then with upgraded HU?
I think that sub box upgrade looks interesting...P)
« Reply #6 on: October 25, 2015, 12:22:55 am »
No vibration at all..
Offline Jarre
« Reply #7 on: October 26, 2015, 09:26:54 pm »
My stereo and subwoofer... amp is under the front passenger seat.
Candy White ED30 :)
Offline Greenman
« Reply #8 on: October 27, 2015, 09:21:58 am »
Sweet.
Is that a 12" sub?
Did you replace the front or back speakers at all?
Are you using the HU to power standard speakers, or are you powering with your after market amp?
BTW - I'm booked in later this week for western audio here in sunny bristol to advise on what they recon would be best for what i'm looking for...:)
Offline Jarre
« Reply #9 on: October 27, 2015, 10:32:46 am »
Sweet.
Is that a 12" sub?
10" sub
Standard speakers powered by the head unit. The head unit has a lot better built in amp compared to the standard vw ones.
Sub enclosure is from Visual ICE.
Sent from my SM-G920F using Tapatalk
Candy White ED30 :)
Offline Greenman
« Reply #10 on: October 27, 2015, 03:40:48 pm »
Sweet.
Is that a 12" sub?
10" sub
I was thinking of buying a 4 channel amp, bridging two channels to the sub, then using the other 2 channels to power either the standard fronts or replacements.  Do you know the wattage of the standard fronts?  I want to try and retain the RNS510.
Anyone ever fitted components up the front and disconnected rear?
