Author Topic: R32/s3 brakes how much  (Read 2262 times)
Offline Mitch H
  • -Receive: 25
« on: October 28, 2015, 06:19:07 pm »
How much should I be paying for r32/s3 brake setup.
I've seen an s3 setup front and rears for £400 Calipers, carriers, lines, discs and pads in good nick although I will probably fit new ones unless they're really good condition.
dansmith180
Re: R32/s3 brakes how much
« Reply #1 on: October 28, 2015, 06:31:50 pm »
Front and rear for £400? Bite his hand off, fronts are usually £300-£350 and rears are £250-£300ish
Offline Mitch H
  • -Receive: 25
« Reply #2 on: October 29, 2015, 08:25:34 am »
I thought they were cheap tbh!
And to throw a spanner in the works I've been offered a full 4 pot kit using toureg calipers for 400
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: October 29, 2015, 11:33:37 am »
Go for the 4 pot from Touareg. :wink:
It uses the Merc ML450 350 mm discs. :smiley:
Offline white91
« Reply #4 on: October 29, 2015, 12:11:28 pm »
Go four pot and let me buy the s3 setup
Offline Mitch H
  • -Receive: 25
« Reply #5 on: October 29, 2015, 04:57:11 pm »
I have done mate, pick them up next week come with discs and pads but might look into some better pads for them :)
also ill ask you this because you seem to know a lot about brakes :D
do the brakets needed change at all if using 55mm or 50mm hubs? I don't think they will but want to check.
also do you think I will need wheel spacers to run this kit behind Pescara wheels?
350mm discs should look sweet :) cant wait
« Last Edit: October 29, 2015, 05:18:21 pm by Mitch H »
Offline Mitch H
  • -Receive: 25
« Reply #6 on: October 29, 2015, 05:30:44 pm »
Just found out they are 330mm discs so dunno what discs they will be?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #7 on: October 29, 2015, 05:44:54 pm »
Not sure what calipers you got that just use 330 mm discs, only Brembo 17Z that have 6 pots. Just Porsche has 4 pot calipers for 330 mm discs, that I know of.
I know these calipers that are 4 pot from the Touareg 3.2 V6 and use 350 mm Merc discs:
You'll need adaptor bolts, hub centring rings for the discs and wheel spacers for the Pescaras (I guess from 7-12 mm).
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #8 on: October 29, 2015, 05:48:49 pm »
If you have a GTI your hubs have 55 mm. Just 1.9 TDI PD105, 1.4 FSI and 1.6 FSI use 50 mm hubs.
Offline Mitch H
  • -Receive: 25
« Reply #9 on: October 29, 2015, 06:15:11 pm »
I think there are (1LE) calipers I have and think they are some sort of merc discs with centre bore and lug holes bored out a little more. Not sure though
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10 on: October 29, 2015, 06:30:37 pm »
Yeah, for what I could find, 1LE uses 330x32 mm discs and it's from the V6 Touareg. Not sure how those calipers that I showed a picture use 350 mm discs... I'll have to confirm with the owner if the discs are really 350 mm or 330 mm. :confused:
