Author Topic: Working On Lowered Mk5's  (Read 3039 times)
Offline rdfcpete
  • -Given: 98
  • -Receive: 52
« on: December 27, 2009, 10:19:45 pm »
You many chaps with lowered MK5's on aftermarket suspension, how do you do jack the car up easily?
I usually use a trolley jack to lift the front of the GTI before placing axle stands underneath, however it grazes and scrapes the splitter as it is. I plan a 35-40mm drop soon but this will mean jack access to the front will be limited for oil changes (which I do myself), even if I remove the splitter  :scared:.
What options are there on a sloped drive way?  :party:
Thanks.
Pete
Re: Working On Lowered Mk5's
« Reply #1 on: December 27, 2009, 10:26:58 pm »
Mine is lowered quite a bit and my trolley jack just squeezes under.  :happy2:
What you could do is buy yourself or make a mini ramp/ or block you can just drive onto giving you the extra inch or 2 to get the jack under.  :wink:
« Reply #2 on: December 28, 2009, 01:49:34 am »
Use the standard jack first and then when it is high enough use the trolley jack :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
Stu...
Offline TomB
« Reply #4 on: December 28, 2009, 02:46:20 pm »
+1
Tom
05 GTI - 18" Merc wheels, coilovers, colour coded Votex kit, all waiting to go on.
