Author Topic: Coilovers  (Read 1588 times)
Offline Gbuck55
Coilovers
« on: October 30, 2015, 06:38:22 pm »
Hey I'm after some advice I'm looking for some coilovers for my mk5 golf gti but not looking to spend the earth can anyone recommend some please  .....thank you
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Coilovers
« Reply #1 on: October 30, 2015, 08:18:22 pm »
Quite a few people on here seem to go with the AP setup for around £400 brand new.. Any cheaper than that then expect a bad ride and poor quality is what I'm lead to believe..
Offline Gbuck55
Re: Coilovers
« Reply #2 on: October 30, 2015, 09:10:19 pm »
Ok thank you
Offline Northy1985
  • Instagram o_n02thy
Re: Coilovers
« Reply #3 on: October 30, 2015, 09:36:36 pm »
I had a set of fk ak streets on my last golf and ride was spot on to be fair no harder than stock springs
Offline th3_f15t
  • -Receive: 183
Re: Coilovers
« Reply #4 on: October 31, 2015, 08:53:34 am »
To be honest, a set of decent springs and anti roll bars would be better for road use than full coilover suspension. A set of progressive springs matched to some anti roll bars will see smooth ride quality, much improved handling and won't cost the Earth to source either.
Offline samiul11
Re: Coilovers
« Reply #5 on: October 31, 2015, 01:21:16 pm »
Im in the same boat, thinking whether to get the fk coilovers or some eichach/h&r springs  :stupid:
Offline AJP
  • -Given: 392
  • -Receive: 316
Re: Coilovers
« Reply #6 on: October 31, 2015, 01:34:24 pm »
The one downside to H&R springs (if being low is a priority) is that they only drop the car by 30mm.
But... in every other way, even with standard shocks, they're brilliant. Ride quality, handling, they do the job very well.
For me, lowering a mk5 GTI to the point where you hold your breath driving over a twig kind of misses the point. With the H&Rs you can enjoy the car for how it was designed - on dodgy b-roads.
If 'lows' is your thing, AP, KW, Bilstein are good.
Offline Adam0604
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,97534.0.html
Re: Coilovers
« Reply #7 on: November 01, 2015, 12:52:48 pm »
If you aren't looking to spend a fortune, I can recommend the FK Highsports.
I'm currently running them and have to say they are very good for the price.
Helpers are out as well, but don't loose too much of the comfort from standard.
Can pick up brand new set for around £400
Offline Mitch H
  • -Receive: 25
Re: Coilovers
« Reply #8 on: November 01, 2015, 02:20:06 pm »
Don't h and r do a lowering spring that lowers around 50mm?
Offline jaffa
  • -Receive: 44
Re: Coilovers
« Reply #9 on: November 01, 2015, 02:35:49 pm »
What do you want from coilovers?
Do you want to go low low?
Do you want to go just lower than springs will allow?
Offline Gbuck55
Re: Coilovers
« Reply #10 on: November 17, 2015, 09:34:31 pm »
Im looking to go low but not super low as I've got a three month old daughter so low but still with a good ride so maybe springs ?
