Author Topic: DSG Gearbox Issue  (Read 1339 times)
Offline Decked
DSG Gearbox Issue
« on: November 02, 2015, 09:07:26 am »
For the last 18 months my Ed30 has had a really jerky clutch engagement in 1st gear.  Slow driving when parking, reversing off the drive or in traffic stop/start is shocking.  As soon as there's load on the gearbox it's fine.  So it really is just the slow manoeuvring it seems to have an issue with, when you'd normally slip the clutch in a manual.
Has anyone experienced anything similar?
Does anyone know how to check if the mechatronic is playing up? I've plugged in VCDS, reset everything and calibrated.  No change.
Meteor S3, REVO Stage 2+, APR HPFP, Milltek TBE, Bilstein PSS10's, EVOM's CAI, Forge TB & DV, Pro-alloy IC & LOBA clutch
Offline afzalmj
Re: DSG Gearbox Issue
« Reply #1 on: November 02, 2015, 05:15:41 pm »
Most likely a mechatronic issue. Search recent posts here, you'll find a specialist in Bristol can fix it.
I had the same issue and got it fixed (jerking in 1st and reverse when setting off).
Offline Decked
« Reply #2 on: November 04, 2015, 06:50:49 am »
Thanks for the reply.  I've had a search but couldn't find anything.
I'll see if there's someone nearer me that could take a look at the mechatronic.
Offline Ma22789
« Reply #3 on: November 08, 2015, 08:58:18 am »
I would try a oil change and filter to start with pal.. Your the guy who done the dsg conversion ain't you ? How's it going I done my ed30 to  :happy2:
  gti ed30 2007 stage 2+ ths loba bcs itg
