Author Topic: Pagid RS4-2s pad build up / vibration  (Read 22038 times)
Offline Bignod00
  • Ginsters are sh*tE!!
Re: Pagid RS4-2s pad build up / vibration
« Reply #15 on: November 03, 2015, 06:19:10 pm »
 :popcornsoda:
Offline flashp
  • -Receive: 65
« Reply #16 on: November 03, 2015, 09:25:42 pm »
I had this with S3 rotors and DS2500 pads. It was pad pick-up.
Not great pads on a trackday.
I have different brakes now but I'm using Pagid RST3's which have had no issues at all.
Gone but not forgotten :-)
Offline Johnsy
« Reply #17 on: December 21, 2015, 11:29:06 pm »
I thought warped discs was an Internet myth.
Interesting thread as Iv not long gone the TTRS caliper route,albeit with the 340 j hooked discs but running a cheap pagid pad for daily use.
You got any track footage?
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=ep0fncb80npg41qc7fr4oceaop&/topic,19740.0.html
« Reply #18 on: December 21, 2015, 11:37:43 pm »
This is pad deposit not disc warping.
« Reply #19 on: December 21, 2015, 11:49:24 pm »
W4nk pads
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #20 on: December 22, 2015, 12:12:30 am »
Usually discs being too hot and warp causing vibration as I had this on mk1 tt and had to replace discs and pads. It was mapped stage 1 with LCR Brembo's.
« Reply #21 on: December 22, 2015, 12:13:41 am »
To warp a disc you have done well. It's 99% more likely to have her pad deposit. Unless you checked them for run out?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #22 on: December 22, 2015, 12:19:07 am »
I did check the discs at work for run out and confirmed they were buggered.
« Reply #23 on: December 22, 2015, 12:20:21 am »
In that case well done. Not the case here tho.
Some dodgy geezer sold me these pads..... Never agsin
« Reply #24 on: December 22, 2015, 12:30:15 am »
Skim / grind your rotors to fix it Rich? Or just give em a battering with different pads/ rs29
Makes me sick what the blues cost when I think of be vibrations when I press the slow pedal
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #25 on: December 22, 2015, 12:31:56 am »
Shame that... dodgy fecklers out there  :fighting:
« Reply #26 on: December 22, 2015, 12:32:54 am »
I didn't get the dti on them but am sure it was deposits from the blues.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #27 on: December 22, 2015, 12:42:11 am »
blues?. pads.
Your running some expensive set up so maybe the pads are fouling the discs and causing vibration but personally I've not heard of this before. Happened to my brothers Carrera 4s so we bought oem parts and once discs and pads were replaced bedding in time was given to around 500 miles. They were fine after that. maybe just a coincidence.
Offline xjay1337
  • -Receive: 377
« Reply #28 on: December 22, 2015, 12:22:30 pm »
Brand new calipers, new fluid, new discs and pads and they'd be warped from road use after 30k? Don't think so.
3 of us having this problem, pretty sure it's the pads.
Plus because it comes and goes, it's not a disc issue.
« Last Edit: December 23, 2015, 01:32:19 pm by xjay1337 »
Offline flashp
  • -Receive: 65
« Reply #29 on: December 22, 2015, 12:33:24 pm »
Dress the disc face to remove the transfer layer and changing compound should fix it.
