Author Topic: US running lights  (Read 6010 times)
Offline Northy1985
  • Instagram o_n02thy
US running lights
« on: November 03, 2015, 06:19:05 pm »
I have just had my running lights enabled in my depo xenon look headlights and just read that they burn out is this true as if the case will turn them back off
Offline xjay1337
  • -Receive: 377
Re: US running lights
« Reply #1 on: November 03, 2015, 08:02:08 pm »
No?
Because if it's set up properly it'll only be the indicators....
Offline Northy1985
« Reply #2 on: November 03, 2015, 08:04:17 pm »
No?
Set up properly.
Offline xjay1337
  • -Receive: 377
« Reply #3 on: November 03, 2015, 08:31:35 pm »
Then you'll be fine.
Only issue is if you run the HEADLIGHTS at a reduced %.
This burns out the bulb/ballast.
Offline Northy1985
« Reply #4 on: November 03, 2015, 08:35:12 pm »
Sorry I mean set up properly? Lol. I brought the lights off a member off here and just put them in my car all I know about them is they have a 5000k hid kit and now running the us running lights
Offline xjay1337
  • -Receive: 377
« Reply #5 on: November 03, 2015, 11:02:34 pm »
I said quite clearly.
"US running lights" meaning the indicators are on with the side lights or dipped beam?
Offline Northy1985
« Reply #6 on: November 04, 2015, 12:20:39 pm »
I have them running with sidelights and obviously when the main beam on. Just read that it can burn the indicator bulb holder out and wires too
Offline xjay1337
  • -Receive: 377
« Reply #7 on: November 05, 2015, 12:32:06 am »
No? Never heard that ever.
Its like a 10w bulb.  Running at a % of that...
Offline Northy1985
« Reply #8 on: November 05, 2015, 12:36:06 pm »
Right i see. Its just there are a set on here for sale same as mine depo brand and said as he been running the running lights has burnt out the holders
Offline SI-R32
  • -Receive: 125
« Reply #9 on: November 05, 2015, 02:56:43 pm »
As with any bulb it will get hot,  even running at a % of full brightness,  perhaps these depo units aren't designed to have a constant hot bulb in the indicator holder?  The oem units are designed for this as this is a requirement on US cars so will be enabled to work out there.
Offline Northy1985
« Reply #10 on: November 05, 2015, 03:02:34 pm »
Im in 2 minds what to do now as i dont really want them burning out may have to just turn them off to stop any un wanted problems
Offline jaffa
  • -Receive: 44
« Reply #11 on: November 05, 2015, 04:21:17 pm »
Had them activated in my hella xenon look headlights for years never had a problem and never changed the bulbs, I also use Amber sidelights to match them
Offline Northy1985
« Reply #12 on: November 05, 2015, 04:37:11 pm »
I wonder if the depo ones are not as good quality as the hella ones and maybe thats the problem.
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #13 on: November 05, 2015, 08:19:24 pm »
I had depo's with US drl from the indicators for over 2 years. Sold the car, but it still has them. Never had a problem
Instagram: stu_nc88
Offline Northy1985
« Reply #14 on: November 05, 2015, 08:27:36 pm »
That's a good enough answer for me then I will just how it goes. Did you have yours coded for xenon without shutters I just see that this has to be done when using these lights, I ain't coded mine
