Author Topic: ED30 KO4 Stage 2+ settings?  (Read 2881 times)
Offline edition30jmr
  • ED30
« on: November 05, 2015, 12:23:40 pm »
Hi guys recently had my ed30 revo'd, just wondering if my settings are correct for stage 2+ the car seems to run great just wondering if I can squeeze anything else from her  :evilgrin:
Boost: 7
Timing: 5
Fueling: 4
Thanks  :jumpmove:
Ed30 Beast!
Offline Madone
  • -Receive: 27
Re: ED30 KO4 Stage 2+ settings?
« Reply #1 on: November 05, 2015, 04:01:01 pm »
I am guessing you had this set by a tuner ?, and they took logs whilst doing it ?, prob not wise to mess with it as they should have used he best settings.
I run boost 9, which is more aggressive, you could try that. Are you running a updated inter cooler ?, wouldn't change the timing. 5 is about right.
Fuel is about right, each car is different so if set by a tuner don't change it would be my advise !
  • ED30
« Reply #2 on: November 05, 2015, 05:53:47 pm »
Yeah tuner set it up with live logging etc! What are your settings yes I'm using a ths cooler, thinking of changing to peron next year!
Ed30 Beast!
Offline adzg60
« Reply #3 on: February 07, 2016, 07:25:16 pm »
Are you on the stock HPFP bud?
  • ED30
« Reply #4 on: February 07, 2016, 07:26:47 pm »
Loba Buddy
Ed30 Beast!
Offline Madone
  • -Receive: 27
« Reply #5 on: February 07, 2016, 08:47:22 pm »
You can't run a stage 2+ map on a stock pump
