Author Topic: Oil pressure warning light  (Read 1938 times)
Offline wilka78
« on: November 07, 2015, 11:02:25 am »
Hi all, has anyone experienced this coming on the dash? Mine doesn't come on when idling, it ticks over great and only comes on when you touch the accelerator peddle. The car is getting oil to the top end so could it just be a sensor or the pressure switch? Anyone had this problem?
Offline Greenman
  • Life is not a straight line!
Re: Oil pressure warning light
« Reply #1 on: November 07, 2015, 04:36:00 pm »
I think a common cause of this is a failing oil pickup pipe.
Steel Grey 2006 Mk5 GTI - R-TECH Stage 1 (268bhp/334ftlb) - BCS Cat Back - Pre-Cat Delete - Carbonio Panel Filter - Rev G DV - 18" BBS CH - Leather - RNS510 - Colour Coded Bumpers and Skirts - ED30 Front Splitter - Eibach Sportlines - Open Fog Grilles - Wind Deflectors.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: November 07, 2015, 04:41:34 pm »
Pickup pipe mate. Stop driving the car before you damage the turbo or bottom end.
Offline wilka78
« Reply #3 on: November 07, 2015, 05:47:35 pm »
Yeah that's what I thought so took the sump off and checked that which wasn't blocked, cleaned the sump out while I had it off and I'm still at a loss as to the cause of it..
Offline vala
« Reply #4 on: November 07, 2015, 06:03:27 pm »
This happened to me recently.
After changing the oil pick up pipe found out the oil filter had collapsed on itself. I thought it was strange as it had recently been changed however I was made aware that there was another valve inside the filter housing which often gets blocked up. I'd never heard from any guides or info about this when I was getting prepped for the full service I completed however it'll be getting regularly checked on all future services.
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #5 on: November 07, 2015, 07:32:27 pm »
Oil pump or a faulty switch. Have a garage test the oil pressure to confirn which
