June 26, 2024, 09:01:39 am
All Things Mk5
Technical Workshop
Camshaft change
Topic: Camshaft change (Read 1298 times)
vala
Can't Read PM's Yet!
-Given: 0
-Receive: 0
Camshaft change
November 07, 2015, 06:16:52 pm »
After checking and changing my cam follower (original had worn through the top), I checked which camshaft I had fitted. Unfortunately it's the revision 'a' camshaft so I need to get a list of tools and items which I require to make the change.
So far my list contains the revision 'b' camshaft and another cam follower.
Would it be worth changing the timing chain and tensioner as well (car has 101k) on the clock.
FWIW it's a BWA engine.
Thanks all
grey golfster
Always Involved
-Given: 79
-Receive: 34
Edition 30 # 993; Stage 2 n a bit....
Re: Camshaft change
Reply #1 on:
November 08, 2015, 06:01:14 pm »
Sorry, can't help you with a tool/material list.
When was last belt and tensioner change?
Regardless of that, i think it would be daft to change a cam and follower, yet reuse the old belt and tensioner.
vala
-Given: 0
-Receive: 0
Re: Camshaft change
Reply #2 on:
November 08, 2015, 06:18:53 pm »
Cambelt and water pump were changed with genuine VAG last December.
Tensioner has not been changed in my ownership (December '13-present). I'd have to take a look through the old invoices to see if it's ever been done.
All Things Mk5
Technical Workshop
Camshaft change
