Author Topic: Temp gauge  (Read 2140 times)
Offline Vwgtiking
Temp gauge
« on: November 09, 2015, 09:28:17 pm »
Just wondering how long it should take to warm up. My mk4 and Audi A4 was always at 90 by the time I get to work which is around 5miles.
Does the thermostat need replacing or is it normal in the mk5 gti for temp to take a while to reach 90?
Offline xjay1337
  • -Receive: 377
Re: Temp gauge
« Reply #1 on: November 10, 2015, 09:03:53 am »
It's pretty well documented if your TFSI takes a while to warm up it's usually the thermostats. It has 2.
3 if you have a DSG.
I like later model ones have 1, or 2 if you have a DSG?
Unfortunately I cant find the thread in question, they matey went very detailed.
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
Re: Temp gauge
« Reply #2 on: November 10, 2015, 09:33:35 am »
I've recently come from a Mk4 Gti to a Mk5 Gti.  Since the colder weather has started in the mornings I find the Mk5 takes quite a bit longer to warm up than the Mk4 did.
When it wasn't as cold it got to 90 fairly rapidly.  Like you, im not sure if its a thermostat issue or just a characteristic of the engine.
Offline v4rley
  • -Receive: 104
Re: Temp gauge
« Reply #3 on: November 10, 2015, 12:24:20 pm »
:P
http://www.mk5golfgti.co.uk/forum/index.php?topic=75756.30
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Temp gauge
« Reply #4 on: November 10, 2015, 12:34:44 pm »
You can use VCDS and check the engine temperature. My Ed. 30 had a failed DSG thermostat although the temp gauge reached 90ºC. I only found out when I fitted a PolarFIS Adv. module and could see that my engine was working at 74ºC. It only reached 90ºC when stopped.
Offline jakemower94
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101848.msg997664.html#msg997664
Re: Temp gauge
« Reply #5 on: November 10, 2015, 01:19:41 pm »
When I bought my ED30, it generally sat at 75 C whilst driving and only got up to 90 C when stationary. Replaced the 'main' thermostat (but also had replacements for the other two just in case!) and it sorted it out. It now gets up to 90 C after about 1-2 miles and stays there  :smiley:
Silver Edition 30 #1438
Offline Vwgtiking
Re: Temp gauge
« Reply #6 on: November 10, 2015, 04:08:25 pm »
How do you test on vcds?
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Temp gauge
« Reply #7 on: November 10, 2015, 06:58:38 pm »
In the engine module you search for the Measuring Block corresponding to the engine temp.
Offline xjay1337
  • -Receive: 377
Re: Temp gauge
« Reply #8 on: November 14, 2015, 01:10:53 pm »
Just for your information, 75 degrees is displaged as 90 on the gauge.
The gauge starts moving at 50 degrees :)
