Author Topic: Trip & dash clock keeps resetting when I turn can on & off...  (Read 4399 times)
Offline rowl3y
« on: November 11, 2015, 08:50:02 pm »
Hi all. I just got my hands on 55 plate gt tdi..
When I turn the  ignition  Off & on it does not remember anything.
I have checked the fuses that are in there and they are fine. There is some missing but I replaced then and still does not save. Or am I missing one ?
The dash seams to work fine tho. I have an after market stereo fitted. This remember radio stations and the time. But does not come on & off when then key is in or out ?
Hope someone can help me
Offline rowl3y
Re: Trip & dash clock keeps resetting when I turn can on & off...
« Reply #1 on: November 24, 2015, 01:50:18 pm »
Bump !
Offline white91
« Reply #2 on: November 24, 2015, 03:26:43 pm »
They have two settings, 1 and 2 you need to change the setting
Offline rowl3y
« Reply #3 on: November 24, 2015, 03:32:07 pm »
Hi. Non of the setting save. The time don't save. Nothing on the dash saves unless it the main miles.
It's like there is main main power to he dash only off the ignition power.
Offline white91
« Reply #4 on: November 24, 2015, 03:43:52 pm »
If the time doesn't save then it's a problem
Offline rowl3y
« Reply #5 on: November 24, 2015, 04:04:57 pm »
Yes the time does not save..  Has anyone ever had this ?
Offline rowl3y
« Reply #6 on: November 24, 2015, 05:59:15 pm »
Offline john87
  • -Receive: 53
« Reply #7 on: November 25, 2015, 09:52:38 am »
Hmm... I might be wrong, but it sounds like there's a problem with the circuit that stays live when you remove the ignition key. Perhaps someone's replaced a relay with one of an incorrect type?
Offline rowl3y
« Reply #8 on: November 25, 2015, 10:04:06 am »
Yes that's what I'm thinking here ?  Where would this relay be ?
Offline john87
  • -Receive: 53
« Reply #9 on: November 25, 2015, 10:05:55 am »
AFAIK the main relays are in the fusebox that can be accessed if you remove the pocket that's situated in front of the drivers' right knee. I had a problem a few weeks back with the car randomly cutting out, and it was relay 460 which was in there.
Offline rowl3y
« Reply #10 on: November 25, 2015, 10:10:38 am »
AFALK?
Could the relay be broke you think. Is that where the dash relay is then ?
Offline john87
  • -Receive: 53
« Reply #11 on: November 26, 2015, 12:23:02 pm »
AFALK?
As Far As I Know  :happy2:
Best to double check in your owners' handbook, but yes, all the dash-related relays should be located below the steering column/in front of the drivers' right knee.
Offline rowl3y
« Reply #12 on: November 26, 2015, 02:52:30 pm »
Is it behind that drop down pocket thing ?
