Author Topic: Fault 001089 - EVAP Emission Control Sys  (Read 8439 times)
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« on: November 12, 2015, 11:02:37 pm »
Hi All
This code is from a friend's car, It's a 2005 Mk5 golf GTI, Engine code AXX.
It recently had the charcoal canister replaced, but the fault came back after a short time.
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2472244
   Coding: 0403000318070060
   Shop #: WSC 00887 210 89731
   VCID: 63C1F9C8A240BA2620-8036
1 Fault Found:
               P0441 - 002 - Incorrect Flow - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 144118 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 06:24:51
             Freeze Frame:
                    RPM: 844 /min
                    Load: 18.4 %
                    Speed: 0.0 km/h
                    Temperature: 72.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.351 V
Readiness: 0000 0000
The engine light stays off for 50 miles then the engine light comes back on, with the same code...
Would like to know a good place to start looking to find the problem !   :fighting:
I Was thinking the N80 valve and surrounding pipework... But without just replacing parts, what way can these be tested?
Silver is the way !
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: Fault 001089 - EVAP Emission Control Sys
« Reply #1 on: November 13, 2015, 02:03:02 am »
Are you sure there's no leak in the system? That small hose that returns the gas vapours has a plastic connector to the canister, is it new as well?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #2 on: November 13, 2015, 07:08:28 am »
Either a leak or an N80.
Easy way to see if the N80 is working would be to remove the pipe going from it to the charcoal can, run the car and you should be able to hear it working on idle, makes a pop/thumping noise a few times a second
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: November 13, 2015, 10:20:42 am »
Yes, i have checked it and all seems to be good.
This i will check,  :happy2:  Should it sound like a clicking noise ?
Silver is the way !
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #4 on: November 13, 2015, 10:32:47 am »
You could desribe as a clicking/ticking noise yes, you will hear the noise coming from the end of the pipe.
Describing sounds is not my forte  :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #5 on: November 13, 2015, 10:42:24 am »
 :happy2:   :signLOL:
As far as i'm aware they can also get blocked up with charcoal...
Silver is the way !
Offline v4rley
  • -Receive: 104
« Reply #6 on: November 13, 2015, 11:10:53 am »
Had this issue too. I change the charcoal canister and code still appeard.
I check the N80 using vcds and could hear clicking. I didn't know what else to try so I brought a new one from eBay for cheap less than £15 and not had issues since  :happy2:
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #7 on: November 13, 2015, 11:14:03 am »
If you remove the pipe from the top of the charcoal canister, you should feel the air pulsations as well as hear them
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: November 13, 2015, 11:31:26 am »
As far as I know the N80 valves, can also cause a vacuum leak...
Silver is the way !
« Reply #9 on: November 13, 2015, 03:25:14 pm »
Had the same.  Had to replace the carbon can, the N80 and the line that goes from the carbon can to the tank vent connection near the brake fluid pot and the fault code disappeared.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #10 on: November 13, 2015, 05:54:54 pm »
Happy Days, hope it is something striaght forward...  Any other suggestions please keep them coming...!
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #11 on: November 15, 2015, 08:05:18 pm »
Removed the N80 valve and was able to blow through it, replaced it with a new one and all seems good, so far...
Silver is the way !
