Author Topic: help with brake warning before mot  (Read 1241 times)
Offline AJG09
  • -Receive: 21
  • My Ride: 2005 mk5 golf 1.6 FSI
« on: November 13, 2015, 05:52:12 pm »
Mot next week and brake pad warning is on!
I read that there is only sensors on the front? and I know the fronts are fine as the car had new discs and pads on the front about 2000 miles ago...
How do I reset the warning light?
Also the brake fluid level is okay I already checked that
Cheers :smiley:
Re: help with brake warning before mot
« Reply #1 on: November 13, 2015, 07:35:47 pm »
You can get the light coded out with vag com or if you take the n/s/f wheel of and check the wire of the pads is plugged in properly
Offline AJG09
  • -Receive: 21
« Reply #2 on: November 13, 2015, 08:22:34 pm »
Yeah its plugged in ok, that's why I'm puzzled a d thought Il just turn it off if it was possible.
Cheers now I need to find someone with vagcom  :wink:
Offline Markyvitch
« Reply #3 on: November 13, 2015, 09:33:01 pm »
it isn't a MOT failure but worth checking the wiring  :happy2:
Offline AJG09
  • -Receive: 21
« Reply #4 on: November 13, 2015, 09:58:49 pm »
Is it not!? Oh well if that's the case then I don't need to rush haha
