Author Topic: GT TDI error code help  (Read 1005 times)
Offline rowl3y
« on: November 14, 2015, 09:22:26 am »
i have vcds and did a scan of my car ...
the main problem i'm having is the Instrument clocks not remembering, Trip count and time or any other stuff
i have a jvc aftermarket head unit fitted,Could it be this
Quote
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ6B083898   Mileage: 260910km/162121miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 FM    HW: 028 101 190 3
   Component: R4 2,0L EDC G000SG  7287
   Revision: 12345678    Serial number: VWZ7Z0E2917302
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 73E3A9971237FA8696F-8026
1 Fault Found:
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
             Freeze Frame:
                    RPM: 882 /min
                    Torque: 44.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001100
                    Temperature: 7.2°C
                    (no units): 0.0
Readiness: 0 0 0 0 0
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 1K0 820 047 DF
   Component: Climatic PQ35   090 0505
   Shop #: WSC 00000 000 00000
   VCID: 6BD3B1F74A0722465EF-803E
3 Faults Found:
00898 - Control Circuit A/C compressor
            010 - Open or Short to Plus
01317 - Control Module in Instrument Cluster (J285)
            008 - Implausible Signal - Intermittent
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 38 AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD02N690
   Coding: 0013112
   Shop #: WSC 00046 412 16384
   VCID: 3B7341B77AE772C68EF-806E
   Subsystem 1 - Serial number: 6332MSME0C5F113EM
   Subsystem 2 - Serial number: 6342MSME0C6C5C14O
   Subsystem 3 - Serial number: 6352QSME06331A4BF
   Subsystem 4 - Serial number: 6362QSME06321E49H
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
            001 - Upper Limit Exceeded - MIL ON
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105B078162
   Coding: 3D3F0B40070003
   Shop #: WSC 00046 412 122880
   VCID: 2A5D74F3857DFB4EE59-807F
3 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 14
                    Reset counter: 73
                    Mileage: 260901 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:03:55
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 73
                    Mileage: 260901 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:03:59
00381 - Databus Instrument Cluster
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 25
                    Reset counter: 113
                    Time Indication: 15
End   ---------------------------------------------------------------------
