Author Topic: TTRS calipers/disc options/clearance  (Read 8544 times)
Offline xjay1337
  • -Receive: 377
Re: TTRS calipers/disc options/clearance
« Reply #15 on: December 02, 2015, 12:44:12 pm »
You don't always need spacers I should add.
It depends on the design of the wheel.
Offline patpong_pete
« Reply #16 on: December 02, 2015, 04:06:59 pm »
i run ttrs discs have done for 6000 miles now no issues
a friend has abused his ttrs discs i have seen them glowing red and he is on his 4th set of pads and done a few track days and they are still good  :happy2:
TTRS disc are fine early type would warp
Dan you have 13mm front each side they must be bespoke
as i have only seen 12mm or 15mm Bizzy says 14mm is fine so what size
12mm to tight or 15mm to wide ?
nice work on your mk2 you are a busy man
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #17 on: December 02, 2015, 04:46:55 pm »
Not strictly true. So do a kit that will fit under 17s. Think it's a 4 pot 330mm kit
Yeah, Brembo 17Z fit under 17'' wheels with 330 mm discs. They just need spacers for clearance. About the same price as the 18Z so for me the 18Z are better value for money.
Offline DANBOY66
  • -Given: 41
« Reply #18 on: December 02, 2015, 05:18:04 pm »
My wheels had been powder coated so I needed the extra 1mm I had the custom made
Dan..
