Author Topic: RNS 510  (Read 2634 times)
Offline BigA91
RNS 510
« on: November 17, 2015, 09:08:43 pm »
Hey guys!
I have a 2008 Golf ED30 and wanted to upgrade to an RNS 510. I've been looking on eBay but have discovered that there's so many different variations and some apparently are 'LED'. I'm guessing the LED is referred to the different type of screen on the unit itself?
Is there anyone on the forum who does these and one more thing, is it a plug and play as most people state on their ad?
Kind regards
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: RNS 510
« Reply #1 on: November 17, 2015, 10:47:56 pm »
Depending on what canbus you have it could be plug and play.  Best to get a vcds scan done of your car to make sure.
You will need an aerial adapter.
If its got a star button on top right corner then its an led.
Sent from my GT-I9505 using Tapatalk
Offline Pashka
Re: RNS 510
« Reply #2 on: November 17, 2015, 10:54:51 pm »
I could supply you RNS and gateway aswell for right price  :happy2:
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: RNS 510
« Reply #3 on: November 18, 2015, 12:04:07 am »
A 2008 Golf shouldn't need a new CAN to be compatible with the RNS-510. But nothing better than checking before fitting the radio. :wink:
Offline PhilNUK
  • -Given: 32
Re: RNS 510
« Reply #4 on: November 18, 2015, 02:23:40 am »
My 08 ed30 was fine with the RNS510 version  P...
Offline rashg60
  • -Receive: 41
Re: RNS 510
« Reply #5 on: November 18, 2015, 10:54:14 am »
Personally I don't feel there's much difference in the later LED version units to the older versions.
I am running a version 'B' head-unit with version 'D' firmware and it works absolutely fine with everything that I need. The older versions are cheaper to purchase as well  :happy2:
And you should be able to fit yourself as they are pretty much plug and play, as the adverts state. Just hope you don't have to change the gateway as that can be a pain (as I figured out the hard way).
Good luck.
Previous motors (in order of succession since 1994):-
VW Golf MK2 GTi 8v
Peugeot 205 1.9 GTi
VW Corrado G60 Supercharged
Volvo C70 2.0 Turbo Convertible
Audi TT MK1 1.8T quattro (225)
Mercedes CLS 320 V6
Audi TT MK1 3.2 V6 Quattro
Audi A4 Convertible 1.8T Quattro
VW Golf MK5 GTi 2.0 Turbo
Offline Pashka
Re: RNS 510
« Reply #6 on: November 18, 2015, 10:57:55 am »
The screen is the bigest difference and performance.
Re: RNS 510
« Reply #7 on: November 18, 2015, 03:02:50 pm »
Yep.  I had an 'A' RNS510 and it was slow as hell to boot up, very slow to load media from the HDD and the NAV was borderline unusable.  I put a 'Q' in recently and that is loads faster and better in all respects.
Mine's an 07 ED30 using original canbus.  The later 510s can have the battery drain issues solved internally with a software adjustment.  Earlier 510s need a newer Canbus to solve the battery drain.....and if you want to change the CANbus, you have to take the wipers off, the scuttle cover, remove the wiper mech and the access panel and then you can get at the CANbus box.   To do it from underneath inside the car is a total nightmare if you have man size hands.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
Re: RNS 510
« Reply #8 on: November 18, 2015, 03:27:06 pm »
My Ed. 30 came from factory with a RNS-510 A that I upgraded the firmware to 5238 modified version. With that firmware it wasn't that slow. Not as fast as my current P and R but bearable in daily use. I read that older firmwares were really slow, though. :confused:
I upgraded to a newer version because older RNS-510 can be a pain to copy new maps to the HDD. :wink:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: RNS 510
« Reply #9 on: November 18, 2015, 03:52:32 pm »
Ive got an LED version H and it doesnt seem any different to the version  b LCD i used to have.
