Author Topic: Intermittent Locking Fault  (Read 3646 times)
Offline Matt81
  • -Given: 47
« on: November 18, 2015, 09:31:33 am »
Hi guys,
I've been searching for an answer to this issue but my fault seems slightly different to the answers I'm finding.
My passenger door has started not unlocking every time.  I often have to press the keyfob unlock a 2nd time (I've turned off selective locking in VCDS so is not expected behaviour).
When it does unlock first time I can hear two unlocking as if the passenger door takes longer than the rest to open.
I wonder if the lock has just become "sticky" or if this is a serious issue.  How can I test this?  What methods can I try to free up the mechanism?
I noticed a while back an intermittent fault on VCDS for the passenger side but can't remember what it said - I'll hook it up again tonight.
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Intermittent Locking Fault
« Reply #1 on: November 18, 2015, 11:14:25 am »
Faulty door lock module.
I had it on my rear passenger door. Genuine unit is pricey so I purchased one off eBay.
fitting requires removal of the entire door leaf. Can be done if you have a decent level of mechanical skill. Garage labour would be extorsionate!
http://www.mk5golfgti.co.uk/forum/index.php/topic,52585.0.html
Offline Matt81
  • -Given: 47
« Reply #2 on: November 18, 2015, 11:36:21 am »
Yuck,
Every time I find a fault with my car it always looks to be a big job :-(
I was hoping as the door wasn't locked shut it wouldn't be so hard but looking at that guide (thanks for that) I think I might have to take to a garage.
Is there nothing else it could be (hoping)?
Offline Matt81
  • -Given: 47
« Reply #3 on: November 18, 2015, 11:44:44 am »
Assuming it is the unit.
As times are tough and I need to keep costs down would you recommend purchasing a used VW unit or a cheap non-VW one?
http://www.ebay.co.uk/itm/Door-Lock-Mechanism-For-VW-Golf-MK5-Front-Left-Seat-UK-Stock-Replacement-/221898885139?hash=item33aa344813:g:EFcAAOSwHjNWCRSe
Guess either option has risks.
Offline Matt81
  • -Given: 47
« Reply #4 on: November 19, 2015, 08:11:25 am »
VCDS:
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Component: Tuer-SG         006 1204
   Coding: 0000950
   Shop #: WSC 01279 785 00200
   VCID: 3A62250BEC5F6CD2112454D-806E
2 Faults Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
            012 - Electrical Fault in Circuit - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            008 - Implausible Signal
Offline Matt81
  • -Given: 47
« Reply #5 on: November 20, 2015, 08:50:39 am »
Just to add.
The times the passenger door does not open it will ALWAYS open if I press the fob to unlock a 2nd time.
