Author Topic: RNS-315, what's needed?  (Read 10846 times)
Offline Bigjimknickers
  • -Given: 55
« on: November 19, 2015, 05:21:48 pm »
Looking into an rns 315 for my golf, it currently has no bluetooth, no gps, no mic.
So my question is, the 315 has integrated BT am I right? So I'll need a gps aerial & a mic to install one on an 2006 GTI?
When I search for the 315 mic it comes up with a BT mic so now I'm getting confused as to what I need for a total install!
Also, is a 315 a good way to go? I want an OE looking radio, with sat nav & a good BT setup for hands free calls/music streaming.
I'm not convinced by the android systems, I think they would irritate me as I'm an apple fanboi!
Offline Pashka
Re: RNS-315, what's needed?
« Reply #1 on: November 20, 2015, 05:03:33 pm »
There is different version of 315, not all has BT integrated. I could supply you RNS315 with BT and DAB aswell.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
  • -Given: 55
« Reply #2 on: November 21, 2015, 08:20:43 pm »
ok, can I get a quote? What else would I need? A mic? What one?
Offline Pashka
« Reply #3 on: November 24, 2015, 10:51:34 pm »
330 with mic and loom plus GPS antenna if needed.
  • -Given: 55
« Reply #4 on: January 05, 2016, 07:17:00 pm »
Still got this pashka?
Offline cenobytez
« Reply #5 on: January 06, 2016, 01:35:17 pm »
would you also need a canbus upgrade with going to a newer generation and an aeriel adaptor?
  • -Given: 55
« Reply #6 on: February 13, 2016, 08:52:09 am »
How difficult is it to tie the mic? Is it an OE one which goes overhead?
Offline Pashka
« Reply #7 on: February 13, 2016, 09:36:33 am »
there is some work to do, just search on google, you will find the pictures how to do it. Yeap, it goes overhead.
  • -Given: 55
« Reply #8 on: February 28, 2016, 08:22:33 am »
Is it a definite that a can gateway will need an upgrade on an rns315 with dab & Bt on a 2006 gti?
Offline Pashka
« Reply #9 on: March 03, 2016, 11:48:38 am »
For sure.
Offline STU175
« Reply #10 on: March 01, 2020, 12:00:13 pm »
For sure.
any one know if i would i need a different can on a 2008 gti pirelli?
Golf Gti Pirelli Edition 3dr Silver DSG 76k - Miltek cat back, Eibach Suspension, K&N Panel filter, Stage 1 map, so far....
Offline terrier
  • -Receive: 41
  • My Ride: GTI now gone
« Reply #11 on: March 01, 2020, 04:19:03 pm »
For sure.
2008 will be ok Ive had march 07 and oct 07GTI, both were fine when updating to RCD510DAB and RNS510 :happy2:
Offline STU175
« Reply #12 on: March 27, 2020, 05:47:36 pm »
ok so i have fitted the unit and all works great apart from i cant access the radio via vcds.
i have tryed controllers radio and navigation but vcds wont talk to either of them.
is there something else i have to do?
i want to access it to change from cd changer to aux in and check it has rearview camera input option available
i could access the old radio fine
thanks stu
« Last Edit: March 27, 2020, 05:50:40 pm by STU175 »
