Author Topic: Intake manifold control runner  (Read 1409 times)
Offline wilka78
« on: November 21, 2015, 09:36:07 am »
Has anyone had this fault code come up on vag com before? I've converted from an axx engine to a bhz and this fault code is making an appearance, the problem is I don't actually know what an intake runner control even looks like, can anyone in the know post a link or a picture? It would be a big help cheers
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Intake manifold control runner
« Reply #1 on: November 21, 2015, 10:20:10 am »
What plugs are you running? If Nology plugs have a read through this thread, was the cause of a dead throttle body and the runner flap fault on mine, got rid of them and no fault since
http://www.mk5golfgti.co.uk/forum/index.php/topic,85105.0.html
Offline wilka78
« Reply #2 on: November 21, 2015, 10:54:08 am »
Tbh I don't know which plugs are in the car, I haven't changed them or had them out to check since I've had the engine put in, but it's definitely something I will check, cheers freddy
Offline wilka78
« Reply #3 on: November 21, 2015, 07:57:02 pm »
Checked the plugs, they're ngk's
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #4 on: November 22, 2015, 09:16:02 am »
Have you got the scan from vag com with the actual fault code? Plugs was a shot in the dark, best to check the simple things first.
Did you check the code in the Ross tech site? Might help narrow it down a bit
http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes
