Author Topic: pluging tyres !  (Read 1791 times)
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
pluging tyres !
« on: December 30, 2009, 12:27:37 pm »
Alrighty, ive just got my monzas back from the refurb company, and fitted two new front tyres and reused the old potenzas (6mm tread). Although ive noticed that one has a screw through it at an angle ! (top of the tyre through the tread).
Are tyre plugs dodgy in any ways for hard driving ?
MK7 GTI - ARRIVING DECEMBER
Offline cmdrfire
    • Commander Fire - my blog
Re: pluging tyres !
« Reply #1 on: December 30, 2009, 12:51:22 pm »
I've had tyre plugs occasionally with no issue or worry. As long as the screw is not through the sidewall or at some crazy angle, if it's close to vertical it shouldn't be a problem.
Offline GTIjames
Re: pluging tyres !
« Reply #2 on: December 30, 2009, 01:02:53 pm »
try and pull it out if you hear air then stick it back in and take it to get repaired.
have had two nails/screws in the tyres first one just pulled out with no problems / air leaks
second time I was on the way up to santa pod the tyre needed repairing - kwik fit £15 - it survived quite a few runs up the strip and a few thousand miles   :happy2:
  • -Given: 64
  • -Receive: 48
Re: pluging tyres !
« Reply #3 on: December 30, 2009, 01:25:49 pm »
james, did it fail in the end or did you just decide to buy a new tyre  ?
Re: pluging tyres !
« Reply #4 on: December 30, 2009, 03:57:05 pm »
I've had a plug in one of my Continentals in the past. No problems whatsoever. :smiley:
Re: pluging tyres !
« Reply #5 on: December 30, 2009, 05:25:20 pm »
i fit tyres for a leaving-as mentioned if the puncture is not on the side wall,the repair willl last as lng as the tyre does with nothing affected to the performance of the tyre
  • -Given: 64
  • -Receive: 48
Re: pluging tyres !
« Reply #6 on: December 30, 2009, 05:30:00 pm »
Ta bud, which type of plug fixing works the best, im aware that there are differant types, or are they much the same
Re: pluging tyres !
« Reply #7 on: December 30, 2009, 05:52:54 pm »
the plug type or mush room patch,s are the best imo-the ones in the first pic,kwick fit use them still
http://www.harvieprema.com/catalogue/plugssteminserts.htm
 but you can use patches if its only a small odject that has caused the puncture
