Author Topic: RNS 510 Rookie Questions  (Read 4779 times)
Offline BradCobbs
« on: November 24, 2015, 01:13:57 pm »
Hi all, I've recently bought a 2008 Golf GTI MK5 that came factory fitted with an RNS510.
I want to upgrade the software/hardware on the unit, along with the latest maps.
Now I know this question has been asked a billion times, but I'm unsure which one my unit will take.
I've attached a photo of both labels on the HU itself and I've also attached a photo of the Autologic VAG module information in the unit.
Could someone please tell me what version my unit is and which update I'll need to do.
Thanks in advance, Brad.
**Update**
Updated to 4020A and all is working well. Seems my unit doesn't like DVD's what so ever- tried a lens cleaner but no luck.
I've bought the latest maps, but it simply won't read in the drive.
Can I put it on SD? As I'm sure I've read it only will accept 2GB. Any help would be much appreciated!
« Last Edit: December 16, 2015, 07:50:41 pm by BradCobbs »
Offline BradCobbs
Re: RNS 510 Rookie Questions
« Reply #1 on: November 24, 2015, 01:18:21 pm »
Couldn't work out how to post photos.
Module Information.
Diagnostic Code: (6) 027
SOFTWARE PART NUMBER: 1T0035680A
COMPONENT DESCRIPTION: RNS-MID
Software Code: Long Coding
Workshop Code: 1316
Software Version: 1020
Hardware Version: H04
Hardware Part Number: 1T0035680A
Series Number: VWZ6ZH5070061
Component Identification: J0506
Stickers on the HU:
1T0 035 680 A
Offline Pashka
« Reply #2 on: November 24, 2015, 10:55:16 pm »
It's the oldest unit mate, A version. Modified5238 fw can be installed on your unit, but I wouldn't go further than 3xxx. Maps up to date are V13. Still most popular V12.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline BradCobbs
« Reply #3 on: November 25, 2015, 07:58:21 am »
Thanks for the reply, I feared it was an A unit!
Will 4210 modified give me the postcode entry? - That's all I'm after really.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #4 on: November 25, 2015, 08:08:32 am »
Even with 3800 you will get 7 digit postcode entry
Sent from my GT-I9505 using Tapatalk
Offline skard
  • -Receive: 245
« Reply #5 on: November 25, 2015, 08:45:34 am »
I had an A, went to 3810 to repartition the hard drive from two to three sectors (you will lose everything but it needs done), then 4020 is the latest safe firmware for this unit, I had it for over two years.
These versions you can update POI via SD etc.
To use v11 or onward maps, you need a modified firmware to allocate more space to maps, otherwise they do not fit. Look for the 60/35/5 version here http://www.rnsfirmware.com/firmware-4020-for-older-units-in-europe-with-hdd-rations-60355/
« Last Edit: November 25, 2015, 08:47:44 am by skard »
Offline BradCobbs
« Reply #6 on: December 16, 2015, 07:52:29 pm »
**Update**
Offline Pashka
« Reply #7 on: December 16, 2015, 09:12:05 pm »
**Update**
It will read up to 32gb, but to get maps installed from SD card, you have to insert custom sw cd, so if your laser is dead it will not help. Maybe you're trying to play divix coded dvd's, it only supports orig. mpeg4 format I think.
Offline BradCobbs
« Reply #8 on: December 16, 2015, 10:14:33 pm »
**Update**
Custom sw cd? Where can I get my hands on one of those? I burnt about 7 Verbatim DVD+R DL with the same software on with no luck. Then tried a TDK CDR and it worked first time.
I've read that these drives are notoriously fussy on which disks they use, it's winding me up, as now I have no functioning nav.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #9 on: December 17, 2015, 10:12:51 am »
My Ed. 30 MY2008 came from factory with a RNS-510 version A, like yours. It only liked Verbatim CDs, to upgrade the firmware. I went initially for this firmware: http://www.rnsfirmware.com/firmware-4120-for-units-in-europe-with-hdd-ratios-60355/#comment-4174, that accepted V12 maps.
I follow what the knowledged people share in this forum: http://gpsunderground.com/forum/volkswagen-seat-skoda/34434-vw-rns-510-skoda-columbus-i-firmware-guide-downloads.html.
So I later upgraded to 5238 modified with no issues. Due to these old units being picky with DVD for map updates I sold it and got a version R instead.
I think I was lucky it read well the V12 maps from a Memorex DVD+R DL. :smiley:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10 on: December 17, 2015, 10:17:23 am »
