September 20, 2024, 02:36:00 am
All Things Mk5
How to Guides / Troubleshooting
Warning light on dash
Topic: Warning light on dash (Read 1578 times)
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
November 24, 2015, 01:51:02 pm »
This light came on this morning on my way to work. Any ideas what it might be?
shail
Always Involved
-Given: 16
-Receive: 32
My Ride:
Re: Warning light on dash
Reply #1 on:
November 24, 2015, 01:52:07 pm »
Tyre pressure monitor. Mine came on todaay too - had a nail in one of the tyres.
lukemk5gti
Just look at my post count
-Given: 28
-Receive: 118
My Ride:
Reply #2 on:
November 24, 2015, 02:11:48 pm »
Second that.
It's most likely a puncture although it could be a faulty air valve.
Best thing to do is check pressure in all 4 tyres and look for the outlier. Should be 2.4bar I think....... It'll tell you inside your fuel cap!
When you have had it repaired or refilled with air
hold
the tyre pressure button (when engine is on) beside the esp button in front of gearstick for a few seconds until you hear a bing and it resets
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #3 on:
November 24, 2015, 02:23:19 pm »
Thanks.
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #4 on:
November 24, 2015, 02:36:24 pm »
I visually checked the tyres. None particularly look flat
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #5 on:
November 24, 2015, 02:40:05 pm »
Can I disable it with vcds?
lukemk5gti
-Given: 28
-Receive: 118
My Ride:
Reply #6 on:
November 24, 2015, 02:42:34 pm »
You need to check it with a tyre pressure monitor... Tyres are safety critical and this possible slow puncture could blow when you're driving full speed on the motorway!!!
Don't just try to disable it, a visual check isn't enough!
You should be able to turn it off even it is a slow puncture by just holding the button for a few seconds but don't do that until you've found the cause!
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #7 on:
November 24, 2015, 02:51:25 pm »
Not had this feature before and I have been driving 16yrs without an issue.
shail
Always Involved
-Given: 16
-Receive: 32
My Ride:
Reply #8 on:
November 24, 2015, 04:04:00 pm »
I've never had it either, but it helped me out today. Tyre was 8 PSI down (only filled them up last week). Visually the tyre looked ok, but on testing it was low on air, and then found a screw in the tread.
Vwgtiking
Won't Shut up.
-Given: 4
-Receive: 3
Reply #9 on:
November 24, 2015, 05:26:22 pm »
How does this function actually work? What happens if get new alloys?
doylebros
-Given: 44
-Receive: 309
Reply #10 on:
November 24, 2015, 05:58:33 pm »
Basically - Abs sensors records wheel revolution - small diameter wheel goes round quicker - flags a fault, warning light comes on.
So the wheel is a fixed size the tyre is the variable thus works with any wheel to suit your vehicle.
There is an expensive version but that's not on the MKV although it is offered on the MKVI or can be retrofitted - see Golfman or Eddie-NL build threads.
All Things Mk5
