Author Topic: Car not dead locking  (Read 4140 times)
Offline rowl3y
« on: November 24, 2015, 05:08:49 pm »
Hi all. I have being to set the car alarm off buy leaving the window open and opening the door. I was hoping the door would not open from the inside but it did.
I have hit the lock bottom twice and still did not do anything ?
Also the alarm did not go off .
Offline doylebros
Re: Car not dead locking
« Reply #1 on: November 24, 2015, 05:21:04 pm »
Did you try every door for dead lock operation?
Two press of the lock button fob disengages the dead lock so only one press to check.
After that it's a scan with VCDS which will show what fault codes are stored.
List of people with the scan tool http://www.mk5golfgti.co.uk/forum/index.php/board,17.0.html
Offline rowl3y
« Reply #2 on: November 24, 2015, 05:57:27 pm »
 Yes I have tried every door. Nothing dead locks
Here is a video
Offline rowl3y
« Reply #3 on: November 24, 2015, 05:58:12 pm »
Also to add. The car alarm is not working also ?
Offline doylebros
« Reply #4 on: November 24, 2015, 06:00:51 pm »
Interesting - a VCDS scan would be my next move.
Offline rowl3y
« Reply #5 on: November 24, 2015, 07:19:36 pm »
Tuesday,24,November,2015,18:25:13:33490VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.3.0 (x64)Data version: 20140905VIN: WVWZZZ1KZ6B083898   License Plate: EJ55 BBJMileage: 260980km-162165mi   Repair Order: ----------------------------------------------------------------------------------------------------------------------------------------------------------------Chassis Type: 1K (1K0)Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7DVIN: WVWZZZ1KZ6B083898   Mileage: 260980km/162165miles00-Steering Angle Sensor -- Status: OK 000001-Engine -- Status: Malfunction 001003-ABS Brakes -- Status: OK 000008-Auto HVAC -- Status: Malfunction 001009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: Malfunction 001016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: Malfunction 001025-Immobilizer -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: OK 000046-Central Conv. -- Status: Malfunction 001052-Door Elect, Pass. -- Status: OK 000062-Door, Rear Left -- Status: OK 000072-Door, Rear Right -- Status: OK 00007D-Aux. Heat -- Status: OK 0000 -------------------------------------------------------------------------------Address 01: Engine        Labels: 03G-906-016-BKD.lbl   Part No SW: 03G 906 016 FM    HW: 028 101 190 3   Component: R4 2,0L EDC G000SG  7287     Revision: 12345678    Serial number: VWZ7Z0E2917302   Coding: 0000072   Shop #: WSC 66565 257 00032   VCID: 73E3A9971237FA8696F-80261 Fault Found:18049 - Please check DTC Memory of A/C Controller             P1641 - 000 -              Freeze Frame:                    RPM: 0 /min                    Torque: 124.0 Nm                    Speed: 0.0 km/h                    Load: 0.0 %                    Voltage: 11.63 V                    Bin. Bits: 00001100                    Temperature: 11.7°C                    (no units): 144.0Readiness: 0 0 0 1 1 -------------------------------------------------------------------------------Address 08: Auto HVAC        Labels: 1K0-820-047.lbl   Part No: 1K0 820 047 DF   Component: Climatic PQ35   090 0505     Shop #: WSC 00000 000 00000   VCID: 6BD3B1F74A0722465EF-803E3 Faults Found:00898 - Control Circuit A/C compressor             010 - Open or Short to Plus01317 - Control Module in Instrument Cluster (J285)             008 - Implausible Signal00819 - High Pressure Sensor (G65)             009 - Open or Short to Ground-------------------------------------------------------------------------------Address 15: Airbags        Labels: 1K0-909-605.lbl   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R   Component: 38 AIRBAG VW8   018 2200     Revision: 02018000    Serial number: 0038MD02N690     Coding: 0013112   Shop #: WSC 00046 412 16384   VCID: 3B7341B77AE772C68EF-806E   Subsystem 1 - Serial number: 6332MSME0C5F113EM   Subsystem 2 - Serial number: 6342MSME0C6C5C14O   Subsystem 3 - Serial number: 6352QSME06331A4BF   Subsystem 4 - Serial number: 6362QSME06321E49H1 Fault Found:01217 - Side Airbag Igniter; Driver Side (N199)             001 - Upper Limit Exceeded - MIL ON-------------------------------------------------------------------------------Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb   Part No SW: 1K0 907 530 F    HW: 1K0 907 951    Component: Gateway         H10 0120     Revision:   H10       Serial number: 2800105B078162   Coding: 3D3F0B00070003   Shop #: WSC 00046 412 122880   VCID: 2A5D74F3857DFB4EE59-807F1 Fault Found:00381 - Databus Instrument Cluster             004 - No Signal/Communication - Intermittent             Freeze Frame:                    Fault Status: 00100100                    Fault Priority: 1                    Fault Frequency: 1                    Reset counter: 118                    Time Indication: 15-------------------------------------------------------------------------------Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR   Component: 01 KSG PQ35 G2  010 0101     Revision: 00010000    Serial number: 00000000000000   Coding: 9B9002085103087F2D040F0F70085FC610A440   Shop #: WSC 00046 412 221184   VCID: 8009765BD381511E1BD-80D5   Subsystem 1 - Component:   Sounder No Answer        Subsystem 2 - Part No: 1K0 907 719 C   Component: Neigungssensor  005 0003   Subsystem 3 - Part No: 1K0 951 177 A   Component: Innenraumueberw.005 02021 Fault Found:01134 - Alarm Horn (H12)             004 - No Signal/Communication             Freeze Frame:                    Fault Status: 01100100                    Fault Priority: 4                    Fault Frequency: 1                    Reset counter: 78                    Mileage: 260989 km                    Time Indication: 0                    Date: 2000.00.00                    Time: 00:03:47End
Offline doylebros
« Reply #6 on: November 24, 2015, 07:37:47 pm »
Where's the door lock modules data from that scan?
Offline rowl3y
« Reply #7 on: November 24, 2015, 07:42:29 pm »
There was no error found on it. All the error are what I have listed
Offline doylebros
« Reply #8 on: November 24, 2015, 08:03:49 pm »
I just found your scan format a bit confusing but now realise it's a diesel not a petrol - silly me! Well I haven't got a clue from what I've seen it would require physically removing panels to look at various items and their behaviour on your vehicle.
Offline rowl3y
« Reply #9 on: November 24, 2015, 08:16:27 pm »
Lol not to worry mate. Yeh I'm thinking the same thing. Where would I start tho.
Where is the alarm fuse and the horn fuse ?
Offline doylebros
« Reply #10 on: November 24, 2015, 08:23:49 pm »
Well I've looked back and read all your posts and feel your vehicle may have a bit history to have the very unusual  faults you've listed!
I would start by followings all the wiring harness and look for a bad repair cause your faults are different to any I've experienced.
I would be looking at the aux heater, cause there favourite for taking harness out when they've had a slack connection - good luck as its a tough challenge ahead.
Offline rowl3y
« Reply #11 on: November 24, 2015, 09:03:22 pm »
Yeh I don't no what going on with it. I know it doing my headin ...
Offline john87
  • -Receive: 53
« Reply #12 on: November 26, 2015, 10:20:59 am »
FYI, two presses on the remote disables the deadlocks. I take it you've tried the inside handles after locking the car with one press?
Offline rowl3y
« Reply #13 on: November 26, 2015, 10:26:19 am »
Yes I have uploaded a video on this.
Offline rowl3y
« Reply #14 on: November 26, 2015, 10:27:03 am »
