Author Topic: RNS 510 Version Q - Battery Drain  (Read 7846 times)
Offline Pashka
Re: RNS 510 Version Q - Battery Drain
« Reply #15 on: February 20, 2016, 02:01:11 pm »
You need to make custom software cd with old software gateway part, but it is not easy and i havent seen anywhere on the net to download. Another thing is to take out the headunit fuse and feed it from another ignition live fuse, but you would loose memory everytime. I can supply precoded gateway for your car and it would be solved as it should.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #16 on: February 20, 2016, 03:21:57 pm »
Have you checked http://gpsunderground.com/forum/car-navi-system/car-gps-systems/volkswagen-seat-skoda/ ?
I think the best firmware gurus share their modified firmwares there. :wink:
Can't complain, they all work very well in my RNS-510s. :smiley:
Offline Pashka
« Reply #17 on: February 20, 2016, 10:34:00 pm »
the thing is for each sw you have to made separate custom cd. If I want to have sw 5xxx, I have to made it myself with 1xxx gateway part. As I know, there was only 2xxx and 3xxx sw with 1xxxx gateway on the net.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #18 on: February 20, 2016, 11:23:52 pm »
You need to read the topics in that forum better. You just need 3 versions for all RNS-510 made.
