Author Topic: Does revo revert to stock once battery is disconnected ?  (Read 7010 times)
Offline winrya
« on: December 31, 2009, 05:20:09 pm »
Is there a definate answer to this. Had my clutch and flywheel done tuesday and car felt well down on power on collection. My tuner doesn't believe it resets but I'm damn sure it's completely different.
It's feeling a bit better now but I imagine it's just me getting used to the lower power?
Appreciate the feedback
Ryan
Offline SteveS
Re: Does revo revert to stock once battery is disconnected ?
« Reply #1 on: December 31, 2009, 05:30:28 pm »
it resets to 000 i believe, so kinda, its still on there, but 000
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline winrya
« Reply #2 on: December 31, 2009, 05:32:01 pm »
cheers. I read somewhere that after a certain distance it reverts back to proper settings? I that truth or rubbish.
Offline SteveS
« Reply #3 on: December 31, 2009, 05:35:52 pm »
not heard that myself
SOLD!! :(
Offline gazbutS3
« Reply #4 on: December 31, 2009, 05:39:39 pm »
thats rubbish, you will need to put your settings back on :happy2:
Offline winrya
« Reply #5 on: December 31, 2009, 06:06:17 pm »
so do I just need access to a select switch?
Anyone got one near telford?  :smiley:
« Last Edit: December 31, 2009, 06:09:47 pm by winrya »
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #6 on: December 31, 2009, 06:07:48 pm »
Yep you will need to reset it with either a select or select plus switch  :happy2:
Offline Deacon
« Reply #7 on: December 31, 2009, 06:17:52 pm »
I've got one (Select +)  for my Scirocco (which I would think would work??) and am not far from Cannock if that helps?
Deacon
Offline winrya
« Reply #8 on: December 31, 2009, 06:23:24 pm »
Deacon
that might get expensive, might come away wanting a Rocco :laugh:
does anyone know if it would work on another car?
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #9 on: December 31, 2009, 06:34:02 pm »
Yes it will work but you will either need to pre-program your Boost / Timing / Fuel settings into one of the presets on the switch or bring a laptop along with the Revo select software so you can directly load your required settings back to the ECU.  :happy2:
Offline winrya
« Reply #10 on: December 31, 2009, 06:42:37 pm »
Deacon
don't happen to have b9 t6 f9 set as a preset do you mate?
Ryan
Offline Deacon
« Reply #11 on: December 31, 2009, 06:50:05 pm »
Not got a clue I'm afraid - just has the presets for 95, 98 and stock.
Deacon
Offline winrya
« Reply #12 on: December 31, 2009, 07:04:39 pm »
It's cool mate, I'll go see mike at votex, I need some detailing gear from autobrite in stoke on my way past anyway. I was just a little worried I'd drive 80 Mins there for him to say the map is perfect, but it appears his collegues were wrong saying it should be fine!
Thanks everyone
Ryan
Offline chungster
« Reply #13 on: December 31, 2009, 07:27:44 pm »
do they actually disconnect the battery then when doing a clutch/flywheel change??
Offline winrya
« Reply #14 on: December 31, 2009, 07:30:50 pm »
they did on mine. The trip computer, time etc had all reset
