Author Topic: Led fog lights  (Read 2445 times)
Offline Northy1985
  • Instagram o_n02thy
Led fog lights
« on: December 04, 2015, 10:58:32 pm »
I'm looking to replace my crackedfog lights for some led items anyone recommend adecent set that will just plug and play
Offline Northy1985
Re: Led fog lights
« Reply #1 on: December 04, 2015, 11:05:34 pm »
Would these be any good eBay item 231770959225
JackL15
Re: Led fog lights
« Reply #2 on: December 05, 2015, 09:06:28 am »
I tried a pair of led fog lights and they looked good but the light output was awful and they threw an error light on the dash. Replaced them with a normal bulb by Philips and they work perfectly and actually light something up.
Offline SI-R32
  • -Receive: 125
Re: Led fog lights
« Reply #3 on: December 05, 2015, 09:09:04 am »
The eBay listing you gave will not throw up errors as the extra resistors will take care of that,  as to light output etc I can't make any comments on that other than give them a go
Offline Northy1985
Re: Led fog lights
« Reply #4 on: December 05, 2015, 09:19:29 am »
Basically I'm going more for the look as I have projector headlights with hid 500k bulbs led sidelights and now just put a set of drl fog grills and the fogs now look silly as everything is bright white and these yellow. And I noticed one fog was cracked so thought complete upgarde rather than just bulb
Re: Led fog lights
« Reply #5 on: December 05, 2015, 09:27:56 am »
You don't use the fogs often enough to worry about the slight mid match in colour?
There are some good upgrade fog bulbs though that would do a better job (when you do need them) and should be able to find one that matches better
Offline Northy1985
Re: Led fog lights
« Reply #6 on: December 05, 2015, 11:59:20 am »
I only was going to change them to led as one have mine is cracked so just thought kill 2 birds and just upgrade them. I aint in no major rush will just do it when i find something
