Author Topic: De-Cat and Lambda question  (Read 14298 times)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: De-Cat and Lambda question
« Reply #15 on: December 07, 2015, 05:40:47 pm »
Correct, sensible driving with the cat fitted if youve had the map tailored for a decat
Lambda spacer can be used to try and avoid the EML if you don't get the map sorted. Of you have the map adjusted then they're not needed
Offline K9
  • VW LifeStyle
« Reply #16 on: December 07, 2015, 06:08:11 pm »
cool! any good place to order a lambda spacer from? i guess it don't hurt to use the spacer and tweak the custom map? Btw should i install a CAI or a good ( K&N panel drop-in filter ) ?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #17 on: December 08, 2015, 07:52:13 am »
A lambda spacer is a lambda spacer, not much to them. Pointless using it if you plan to have the map adjusted though.
A decent intake beats the factory airbox in terms of performance
Offline K9
  • VW LifeStyle
« Reply #18 on: December 08, 2015, 07:54:17 am »
What is a decent brand for CAI?  Can the car be driven normaly after the de-cat is fitted before the map is adjusted?
Writen with my fingers
Offline Gaz
« Reply #19 on: December 08, 2015, 10:47:17 am »
Fit a decat and see if your EML even comes on, it may already be disabled in your current map file.
If it comes on, get the mapper to map it out so you dont get EML.
If your map is to suit a car with a cat in place, then you remove cat and only have map tweaked to rid the EML, then you put cat back on for MOT- you can still drive it hard as it was mapped with a cat anyway.
Only time you couldnt drive it hard with cat fitted is if its been mapped without one (and itll have smaller downpipe than a decat).
The rear lambda which you get mapped out is not important, its there to make sure the cat is doing its job, hence why it pops a EML when you remove cat. The front lambda is the one controlling the fuelling.
Offline K9
  • VW LifeStyle
« Reply #20 on: December 08, 2015, 02:51:57 pm »
Great info m8! Will install the de-cat myself and see if i get the EML or not. how much can a tuner charge to tweak the map?
Offline K9
  • VW LifeStyle
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #22 on: December 09, 2015, 10:16:19 am »
Yes, you want some of that, with http://www.ebay.co.uk/itm/281743038060?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
to help seal it and protect it ....  :happy2:
It will smell for a while  :rolleye:
Silver is the way !
Offline K9
  • VW LifeStyle
« Reply #23 on: December 09, 2015, 10:49:56 am »
Is the coating really needed or can i just wrap it and ziptie it up?
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #24 on: December 09, 2015, 11:00:25 am »
I wouldn't advise wrapping it at all personally, but each to his own
Offline Paradox1
  • -Given: 41
« Reply #25 on: December 09, 2015, 11:14:50 am »
You dont need it but it helps
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #26 on: December 09, 2015, 11:21:22 am »
Hi Dan, some people like to wrap and some don't, why would you not advice it, anno ceramic coating would be best...
Silver is the way !
Offline K9
  • VW LifeStyle
« Reply #27 on: December 09, 2015, 11:52:15 am »
Will 10m wrap do the DP?
Offline Paradox1
  • -Given: 41
« Reply #28 on: December 09, 2015, 11:59:17 am »
Yeah that will be enough
Offline K9
  • VW LifeStyle
« Reply #29 on: December 09, 2015, 12:46:04 pm »
Any how-to with pics to remive DP?
