Author Topic: 225/45/18 Rear and 225/40/18 Front  (Read 2855 times)
Offline Nasir
« on: December 08, 2015, 04:08:47 pm »
Hi,
I just had my tyres changed. I noticed the previous owner (unintentionally) fitted the wrong size tyres on one axle (size 225/45/18).
The problem is that the wrong sized tyres are brand new!
Is it okay to drive with the 45 profile on the rear and 40 profile on the front for a couple of months? Unless it's a safety issue, I can't justify binning new tyres.
Shadow Blue 2007 GTI DSG (Standard)
Offline andyR43
Re: 225/45/18 Rear and 225/40/18 Front
« Reply #1 on: December 08, 2015, 05:40:48 pm »
No reason why the profiles would need to be the same so carry on driving!!  :driver: :driver:
Keeping it original..............or not!!
Offline Chris92
  • -Given: 33
« Reply #2 on: December 08, 2015, 09:30:48 pm »
It'll be fine as longs as each axle has the same tyres on both sides of the same axle.
Offline john87
  • -Receive: 53
« Reply #3 on: December 09, 2015, 10:02:35 am »
... unless you're running an R32 or something else with 4 wheel drive, in which case you'd suffer serious damage to the system!
Offline Nasir
« Reply #4 on: December 09, 2015, 10:33:05 am »
Okay thanks fellas.
Could this be the reason that my steering angle sensor light, ESP and TPMS light are coming on and going off?
I.e., the wheels on the two axles rotate at different speeds, confusing the system?
Offline xjay1337
  • -Receive: 377
« Reply #5 on: December 09, 2015, 10:36:31 am »
Yes possibly.
Although I ran 215/40 and 225/45 and had no such problems.
Offline Nasir
« Reply #6 on: December 09, 2015, 10:39:22 am »
Yes possibly.
Hmm, food for thought. The previous owner did mention that the light only came on when he switched from winter tyres to these (wrong sized) tyres. Even did a 4 wheel alignment to try and correct it.
Cheers mate.
Offline MrBones
« Reply #7 on: December 09, 2015, 12:20:37 pm »
Yes this is true for 4 wheel drive/ 4motion's ...it will cause problems with the Heldex
Offline Nasir
« Reply #8 on: December 09, 2015, 12:45:39 pm »
Yep I can imagine. I have a GTI, though.
