Author Topic: bi xenons fitted ALL SORTED NOW :)  (Read 6093 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« on: December 08, 2015, 05:20:38 pm »
Hi guys,
Fitted my bi xenons in today but the indicators on both sides aren't working and I was also trying to turn the drls off as one isn't working.
Anyone in the know who can help me would be appreciated.
M
« Last Edit: December 09, 2015, 05:19:03 pm by r5gtt »
Offline Rossimac
  • -Given: 78
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,90767.0.html
Re: bi xenons fitted help please
« Reply #1 on: December 08, 2015, 05:29:34 pm »
Did you use kufatec adaptors or wire them manually?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: December 08, 2015, 05:54:20 pm »
Hi, I just plugged them in direct as the seller said I didn't have to use adaptors as they are plug and play.
These aren't proper xenon headlights!.
These are copies and I've fitted a hid bulb kit to them.
M
Offline Rossimac
  • -Given: 78
« Reply #3 on: December 08, 2015, 06:09:06 pm »
Ahh, sorry, no help here! Thought they were OEM xenons.
Good luck!  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #4 on: December 08, 2015, 06:38:45 pm »
Lol that's okay hopefully someone is out there  :sad1:
M
Offline dlbogdan
« Reply #5 on: December 08, 2015, 06:43:18 pm »
Did you hmmm.. check the bulbs ?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: December 08, 2015, 06:53:36 pm »
Brand new bulbs and wiring as they were burnt out on the driver side but I did a good job of repairing them.
the amber bulbs are the side lights and always on as seller told me but left hand only works.  :confused:
Okay been told the the orange 501 are definately the side lights. That could just be a blown bulb/fuse
The ones you repaired are the indicators. I've put led canbus in those I have repaired so need to get them working tomorrow as I can't drive the car like that.
Going to have a look at the fuse tomorrow and re check the bulbs but they are new as I've also used the same for my side lights on the oem headlights so I know they are working.
I'll need to turn off the remote coming home lights as this will limit the lifetime of the hid bulbs and ballasts.
M
« Last Edit: December 08, 2015, 07:43:40 pm by r5gtt »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: bi xenons fitted ALL SORTED NOW :)
« Reply #7 on: December 09, 2015, 05:19:40 pm »
Everything working as they should :)
« Last Edit: December 09, 2015, 06:25:13 pm by r5gtt »
Offline dave mc
« Reply #8 on: December 22, 2015, 03:50:40 pm »
No headlight washers tho.
2007 gti edition 30 with every factory xtra
Offline Rossimac
  • -Given: 78
« Reply #9 on: December 22, 2015, 04:53:45 pm »
Not needed on Mainland UK, so why fit them?
Offline dave mc
« Reply #10 on: December 23, 2015, 03:07:16 pm »
Lucky u i need them here in northern ireland
Offline Rossimac
  • -Given: 78
« Reply #11 on: December 23, 2015, 04:18:13 pm »
Same here :(
T-pipe from the windscreen washers! MOT in January....
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #12 on: December 23, 2015, 09:16:03 pm »
If I wish I could fit them but I certainly don't need them tbh
Maybe if I replace the number with a jetta one and it has washers I will as it's a cool gadget  :jumpmove:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #13 on: December 23, 2015, 09:18:01 pm »
Regards not needing them on UK mainland??? Some testers WILL fail you for not having them but I'll check with dave or Gareth at work and they can advise me better as I don't have an mot cert  :sad1:
Offline Hannakournikova
« Reply #14 on: December 23, 2015, 09:59:23 pm »
Same here :(
So if your car has oem Xenons but no headlight washer is a fail?
