Author Topic: Put new battery in, dash lights won't go out.  (Read 4979 times)
Offline ColinMKV
« on: December 08, 2015, 10:54:39 pm »
I replaced my battery in my 2005 Golf GTI MKV because the car needed jump started every time I turned the engine off. With the old battery, if it ran out of power and the car didn't start I would get the following dash lights: Power steering light, type pressure ligh and ESP light. The steering while these lights were off is very heavy but with the old battery they usually went off within about 50 miles, on one occasion it took 200 miles of constant driving for it to go off. Now the problem is, when I changed to the new battery those lights were all still on which I expected because a new battery would need a bit of a run in I guess but after 300 miles with the new battery in they're still not going off, steering still heavy, no esp. I've tried going on a straight road and going full lock to full lock but to no avail. I'm wondering if I just need to go for a constant long drive or something for them to go out? I'm out of ideas. Any help would be greatly appreciated. Cheers
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Put new battery in, dash lights won't go out.
« Reply #1 on: December 08, 2015, 11:01:04 pm »
Turn car on, turn steering wheel full lock to the left and hold for 10 seconds and then full lock all the way to the right and hold it for 10 seconds and then straighten the steering wheel.  It should go out
Sent from my SM-G928F using Tapatalk
Offline ColinMKV
« Reply #2 on: December 08, 2015, 11:01:57 pm »
Thanks for the suggestion pal. I'll try that just now and get back to you.
Edit: Unfortunately didn't work mate, cheers though!
« Last Edit: December 08, 2015, 11:07:15 pm by ColinMKV »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #3 on: December 08, 2015, 11:38:28 pm »
Take the negative off and try again?.
You only need to drive a couple of yards and they should go out tbh  :confused:
M
Offline ColinMKV
« Reply #4 on: December 09, 2015, 02:03:03 am »
M
Just tried that and went out for a 50 mile drive. Still got all the dash lights on. Power steering, ESP and type pressure.  :stupid: :stupid:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #5 on: December 09, 2015, 06:11:46 am »
You may need to perform basic settings using vcds and then go for a drive
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #6 on: December 09, 2015, 11:31:10 am »
What a pain. try what raz said.
M
Offline th3_f15t
  • -Receive: 183
« Reply #7 on: December 09, 2015, 12:13:00 pm »
As mentioned, get a diagnostic kit onto it, clear any fault codes and hopefully it'll all go away. It may be because the various control modules have logged some serious fault codes (because of the dying battery) and they won't go away until manually removed.
Offline ColinMKV
« Reply #8 on: December 11, 2015, 01:08:40 am »
Just an update. Was out driving this afternoon, going round a roundabout and as I was turning the steering wheel hard to exit the roundabout, all the lights on the dash went off and had power steering back, almost went into a wall because I was turning so hard because of having no power steering. Forgot how amazing the steering feels when it actually works! Chuffed to bits. Thanks for all the suggestions guys.
« Reply #9 on: December 11, 2015, 01:12:24 am »
Glad the lights have gone out at last
Offline ColinMKV
« Reply #10 on: December 11, 2015, 01:21:24 am »
Me too mate. Was like driving a truck :grin:
« Reply #11 on: December 11, 2015, 01:27:40 am »
Bet your arms are like hercules :signLOL:
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #12 on: December 11, 2015, 09:02:04 am »
Haha, I've been there too, driving it without PAS, it's an effort for sure...  The full lock left and right and drive usually works though unless there's another problem stopping the system from re calibrating (mine recently was a duff rear sensor)
