Author Topic: P0299 fault code car in limp mode  (Read 7606 times)
Offline SyGolf5Gti
Re: P0299 fault code car in limp mode
« Reply #15 on: December 23, 2015, 05:50:45 pm »
I might be in a lot of trouble as my cam follower was totally worn through there is a hole the size of my index finger :surprised: Iv replaced the cam follower but could this mean my cam lobe is affected? First thought that came to mind was where did those pieces go. The last time we changed oil and did an engine flush there fine metal shavings in oil pan when we cleaned it out I had wondered where these came from.
Take it easy.. and if its easy.. Take it home!! :driver:
Offline jhook661
  • -Receive: 20
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,98678.0.html
« Reply #16 on: December 23, 2015, 06:01:58 pm »
That's not good dude
Sump off clean that through
Major engine flush
Oil pick up pipe
And new camshaft no doubt and  probably new fuel pump too maybe more things too   :sick:
« Last Edit: December 24, 2015, 01:53:19 pm by jhook661 »
Modded Golf gti CDL engine TTE420 turbo
Rtech 440bhp 429ftlb
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #17 on: December 23, 2015, 10:56:07 pm »
 :sad1: That's not good Sy, as jhook661 has already said, your fuelling is shagged, new pump, camshaft and hope there's no other damage. Drop the sump and through clean. Let us know how you get on
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #18 on: December 24, 2015, 07:38:41 am »
Cam and pump damage, both likely to need replacing
Offline SyGolf5Gti
« Reply #19 on: December 26, 2015, 08:32:15 am »
 :sick: exactly what I was dreading... il take it in to the dealer and see if my warranty will cover *fingers crossed
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #20 on: December 26, 2015, 08:47:18 am »
Good luck Sy, it's going to depend on how comprehensive your warranty is, although the cam follower is not considered a serviceable part, so that should go in your favour  :happy2:
Offline SyGolf5Gti
« Reply #21 on: February 12, 2016, 02:49:55 pm »
Hi guys
So after a long battle my warranty agreed to pay, new cam shaft, new cam follower and hpfp pump. All was fitted, I collected the car and was running beautifully until today after sitting in traffic heard a slight, ticking/knocking sound from the engine, decided to head back to the dealership and just before I got there taking off from a robot.. boom! car starts jerking again,  :sad1: you put your foot down it jerks and cuts petrol, just like before... They plugged it in and its still giving the low fuel pressure error code. Now I really don't know, they asked me to bring the car in Monday so they can check it again. if all these parts were replaced what else could the problem be :sick:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #22 on: February 12, 2016, 03:03:19 pm »
I'm sorry but you should have put your foot down and said no your keeping the car till it's fixed as something worse could happen driving it away.
Get them to check your low pressure pump and injector status.
Check for any boost leaks and maybe even the N75 boost valve.
Hope you sort it.
R5
