Author Topic: Intermittent starting problem  (Read 3744 times)
Offline JMP
« on: December 12, 2015, 04:31:20 pm »
I have a BWA gti with dsg. K03 and revo stage 2. I have experienced now twice a starting problem. I turn the key and engine turns happily but it doesnt even try to start. Nothing,it just spins the engine happily. When I let go off the key and try to start again, it fires right up. I had no fault codes and Im not getting any misfires on any cylinders. Any ideas what this could be? Happened twice in a few weeks time. Kind of a feels like a fuelling issue, since it doesnt even try to start any cylinders. Otherwise engine is working fine.
Offline JUNNYAK47
Re: Intermittent starting problem
« Reply #1 on: December 12, 2015, 04:35:52 pm »
Iv been having a similar problem. Is it something like this?
Red Edition 30 - Stage 1+, APR Remap, Catback Milltek, ITG maxogen induction, APR HPFP,
Offline JMP
« Reply #2 on: December 12, 2015, 04:58:16 pm »
Well almost.. Yours did try to start, mine doesnt even try. However mine spins a lot faster so you might want to check your battery. I had similar issue as you now, and it went away with new battery.
Harrythomas127
« Reply #3 on: December 12, 2015, 07:00:17 pm »
Better than mine!
Offline doylebros
« Reply #4 on: December 12, 2015, 07:34:19 pm »
The last one I fixed like that had a defective PCV and air leak on the intake - it was a standard intake with a tiny crack - have it scanned with VCDS and see if there's any fault codes.
Offline doylebros
« Reply #5 on: December 12, 2015, 07:36:32 pm »
Your could be the ignition switch failing, if you have it scanned it would show as and electrical fault and a stored DTC to match.
https://m.youtube.com/watch?v=AOoraqzN7Hs
« Last Edit: December 12, 2015, 07:43:24 pm by doylebros »
Offline JMP
« Reply #6 on: December 12, 2015, 08:13:45 pm »
I scanned only the engine module for faults, I need to scan the rest also. Thanks for this tip, I think this is a good possibility.
Offline JUNNYAK47
« Reply #7 on: December 13, 2015, 07:56:08 am »
Thanks for pointing that out. I will have a look at the air intake
Offline JMP
« Reply #8 on: December 13, 2015, 03:45:10 pm »
I scanned the rest of the modules, but no more fault codes for this. Crap. I guess I will just keep driving until it fails to start completely.
Offline seiko
« Reply #9 on: December 14, 2015, 11:32:41 am »
i would go with a revision pcv fixed this on mine,
