Author Topic: RNS510 Firmware Upgrade Dealer/Supplier  (Read 36484 times)
Offline pazz
« on: January 01, 2010, 07:16:25 pm »
Is anyone aware of a company or Volkswagen dealer who would offer to upgrade the RNS-510 firmware?
Call me a bit of a girl :pomppomp:, but I dont want to risk bricking my RNS-510.
I enquired at my local dealer but they tried to sell me a £100+ maps DVD  :congrats:
I'd like 266x as I'm stuck on 900 at the moment, I've got a new "Q" gateway ready to be fitted/coded.
« Last Edit: January 25, 2010, 07:47:18 pm by pazz »
Offline 182_blue
  • -Receive: 54
Re: RNS510 Firmware Upgrade Dealer/Supplier
« Reply #1 on: January 01, 2010, 08:07:34 pm »
Is this an A revision unit ?, Going to 2660+ can cause more issues than just needing the new canbus
also you may as well do it yourself, because whoever does it will probably make you sign a disclaimer in case it goes wrong
Phil Mcavity
« Reply #2 on: January 01, 2010, 08:11:11 pm »
I cant even get my unit to show me what Firmware is installed. Mines a Version B but when i press the buttons <>+ i, then setup, nothing happens!! :confused:
Ive also tried just holding down the setup button, but all that does it bring up the Radio service test page showing FM/AM/DAB sig strenghts?
Any idea's chaps?
Offline 182_blue
  • -Receive: 54
« Reply #3 on: January 01, 2010, 08:19:40 pm »
Any idea's chaps?
it needs VCDS to enable it on newer units (an adaption change)
Offline 182_blue
  • -Receive: 54
« Reply #4 on: January 01, 2010, 08:23:50 pm »
this one i think
Using Vagcom/VCDS open Channel 37 – Navigation, go into adaption and change channel 50 to 1 (will be 0).
To enter the test/setup mode when the RNS 510 is operating press and hold the setup button, keep holding it when the radio menu appears and shortly after the test menu appears . I had to reboot my unit after coding it but it may be possible a power cycle is enough.
« Reply #5 on: January 01, 2010, 08:29:12 pm »
But as far as I know that adaprion change is only applicable from 266x and later.
Or do you have details which firmwares it is applicable to? :confused:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #6 on: January 01, 2010, 08:38:16 pm »
On mine I had to make that adaption change when I went to 1100 IIRC  :smiley:
Offline pazz
« Reply #7 on: January 01, 2010, 09:09:30 pm »
Version B. The only issue I am aware of is the battery drain on MY 07 or earlier cars due to old canbus gateway. Mine is March 2007 reg so I presume MY06? (I've not checked this yet).
I had to make the adaption change to get it show the secret menu and I'm only running f/w 900.
« Last Edit: January 01, 2010, 09:11:01 pm by pazz »
Phil Mcavity
« Reply #8 on: January 01, 2010, 09:53:40 pm »
By getting another party to do the upgrade you can pass on the risk.
Good Point. Will have a chat with my local Master Tech.
« Reply #9 on: January 01, 2010, 10:05:12 pm »
So you don't know the exact origin of your unit yet you want someone else to accept responsibility for upgrading it.
I honestly can't see anyone taking that on, why would they? Especially a VW dealer.
Offline ollie288
« Reply #10 on: January 01, 2010, 10:16:58 pm »
+1
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #11 on: January 01, 2010, 10:18:40 pm »
^^^^ X2  :chicken:
Offline golfman
  • -Given: 17
« Reply #12 on: January 02, 2010, 08:56:38 am »
Not entirely true as i have an A revision unit with a new s canbus with fw 2660 and voice control on the RNS510!!!
Sometimes when i start the car it's in germany(but it only lasts for 2 seconds) :happy2:
scott.
Vag-com Hex+Can in scotland
I Hate Timewasters...
« Reply #13 on: January 02, 2010, 11:09:39 am »
scott.
I have an A rev unit on 266x firmware but we failed with voice control.
Can you post up your coding or an autoscan please?
Offline golfman
  • -Given: 17
« Reply #14 on: January 02, 2010, 11:24:00 am »
scott.
Sorry i don't have vagcom and it was darren(mortigttdi) that fitted it for me :happy2:
send him a pm and im sure he can help you out!!
scott.
