Author Topic: Help needed  (Read 1459 times)
Offline Gbuck55
Help needed
« on: December 17, 2015, 05:30:13 pm »
Hi I have a mk5 golf gti o5 plate it was fine then I was told the rocker cover gasket was going so I had it change after it was changed the car revs would go up to
20 then back down to 10 and carry doing
This and iding very poor so change the pcv valve and the car carried on iding poor so I changed the air mass meter but it's still iding poor and the revs go up and down slowly and help would be nice cheers
Offline doylebros
Re: Help needed
« Reply #1 on: December 17, 2015, 06:10:41 pm »
The air box/air filter housing held on with those difficult 4 X rubber support - remove it and look underneath check for any small even tiny fractures - if you find any that's most likely the cause of the hunting - prep & repair with with suitable adhesive.
Offline Gbuck55
Re: Help needed
« Reply #2 on: December 17, 2015, 06:15:33 pm »
I'll look at that tomorrow thanks for your help
