Author Topic: Removing seats  (Read 3954 times)
Offline Pesky jones
Removing seats
« on: December 19, 2015, 07:30:09 pm »
I was planning on removing my heated leather seats tomorrow to clean the car interior thoroughly, if its not too much of a job
Ive read theres four m10 triple square bolts in each front seat, and eletrical connections.
Ive also read the battery needs disconecting. How do I go about disconnecting the battery? Will disconnecting the bartery lead to any problems?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Removing seats
« Reply #1 on: December 19, 2015, 07:39:19 pm »
In all my years of removing car seats with heaters or electrics I've never disconnected thr batter but for you safety I'd take the negative terminal off only.
If you have a coded radio then make sure you have the code but again I found this unnecessary as the genuine stereo usually works with battery off even for 4 hours plus.
Take a note of your mileage trip if your keeping count of the miles.
« Last Edit: December 19, 2015, 08:54:27 pm by r5gtt »
Offline Pesky jones
Re: Removing seats
« Reply #2 on: December 19, 2015, 07:53:08 pm »
I dont know if I have a coded radio, its the mfd2. If it is coded how do I take the code?
What do you mean by keep track of mileage? Surely it wont change if I disconnect the battery?
How should I disconnect the battery, undo the nuts for positive and negative and then put them to one side but.not touching any metal. Would it be a good idea for safety to wrap the ends in insulating tape? Can I touch the wire in order to wrap it?
« Last Edit: December 19, 2015, 07:56:46 pm by Peskyjones »
Offline white91
Re: Removing seats
« Reply #3 on: December 19, 2015, 08:58:40 pm »
It's really easy mate, just whip the -ve off, take the seats out job done. Just be careful when moving seats not to scratch anything as they're heavier than they look
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Removing seats
« Reply #4 on: December 19, 2015, 08:59:12 pm »
I don't know what stereo that is but mine didn't need recoding.
I meant the trip computer part not mileage as that will never change.
Just undo the 10mm nut on negative side and pry the terminal off and MAKE SURE NOT TO TOUCH IT as you'll melt your hands  :jumping: ONLY KIDDING  :laugh:  just take it off and move it out the way till you've refitted the seats back and connected all wiring. The you can refit the negative terminal and all done. Dont forget to reset the time.  :wink:
Offline Pesky jones
Re: Removing seats
« Reply #5 on: December 19, 2015, 10:55:51 pm »
Cheers. What happens if I do touch the negative then?
Why shouldnt I disconnect both? Ive read both should be disconnected
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Removing seats
« Reply #6 on: December 19, 2015, 11:14:32 pm »
The world will end and that's that  :sad1:
You may disconnect both if you would prefer to but to save you the trouble and just do the - minus is all you need to do.  :smiley:
Always wear protective gloves as acid from a battery will cause irritation and burns so don't touch your face etc.
Offline Pesky jones
Re: Removing seats
« Reply #7 on: December 20, 2015, 10:46:51 am »
Is there anything I could do that would electrocute me?
Offline white91
Re: Removing seats
« Reply #8 on: December 20, 2015, 10:55:56 am »
Put your tongue on it
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Removing seats
« Reply #9 on: December 20, 2015, 11:08:35 am »
:laugh: :P
Whip those seats out and hoover up those runners points peskyjones  :happy2:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=68dhlmb2vqbatoc558lloek9ht&/topic,90967.msg917089.html#msg917089
Re: Removing seats
« Reply #10 on: December 20, 2015, 12:17:23 pm »
Put a blanket over the door cill just incase.
05 | Tornado Red | DSG
Offline Pesky jones
Re: Removing seats
« Reply #11 on: December 20, 2015, 12:35:18 pm »
Lol very funny, anyone?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Removing seats
« Reply #12 on: December 20, 2015, 12:38:39 pm »
I was being serious I did this when i took mine out. The seats are heavy one slip and you damage the door cill.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Removing seats
« Reply #13 on: December 20, 2015, 01:40:55 pm »
I think peskyjones is either pulling our legs acting  :stupid: or he's not reading the replies as the blanket will keep you from damaging the sill.
The earth removed will prevent any electrical contact and protect the vehicles electrics if you happen to chop into thr wiring.
Remember to plug everything back in before you post a how to repair your heated seats  with air bag lights on :happy2:
Offline Pesky jones
Re: Removing seats
« Reply #14 on: December 20, 2015, 03:25:30 pm »
I found two quid!
