Author Topic: HELP car wont start  (Read 6367 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: HELP car wont start
« Reply #15 on: December 21, 2015, 08:39:27 pm »
Get some easy start in there mate, bet it will start lol
Okay pumps working then?.
Try the above  :wink: Sometimes it's a fuelling issue as ive had the odd one causing this issue when I used to work with a 60 year old bloke who knew his diesel engines but now deceased so here's hoping I'm right.
Easy start? oh god. Dont cars get addicted to that?
It's not a drug addict  :laugh: Sometimes it's resolves the problem.  :driver:
If I were there I'd help you out mate  :sad1:
Offline doylebros
« Reply #16 on: December 21, 2015, 08:41:18 pm »
Look at poster five for the marks to align for your checking procedure http://www.clubgti.com/showthread.php?267441-Servicing-Newer-VW-s
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #17 on: December 21, 2015, 08:44:14 pm »
I've done 5 of these t belts and never had the tool so used a 4.5 mm drill bit to lock the cam up closest to bulk head. haha  :ashamed:
« Last Edit: December 21, 2015, 08:52:03 pm by r5gtt »
Offline V3trox
« Reply #18 on: December 21, 2015, 11:18:49 pm »
Will report back tomorrow lads...if i can get child cover
I also want to go out on a limb and assume the "oil pressure warning" that comes on after a lot of cranking is normal?
« Last Edit: December 21, 2015, 11:22:09 pm by V3trox »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #19 on: December 21, 2015, 11:29:27 pm »
Did this light presuming its red come on when you had your car running and just before it cut off???
Offline V3trox
« Reply #20 on: December 21, 2015, 11:33:45 pm »
No, just when you've been cranking it for a while
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #21 on: December 21, 2015, 11:38:35 pm »
Then your all good  :happy2:
Just don't forget to get you self a can of easy start which isn't £2 anymore  :mad:
Offline V3trox
« Reply #22 on: December 21, 2015, 11:42:40 pm »
if it starts and runs with easy start. What would the problem be?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #23 on: December 22, 2015, 12:02:53 am »
Well when amd me 60 year old pal used this to start one up min 2014 it fixed itself.
Sometimes an old fuel filter needs replacing due to blockage. Could also be the cam sensor but no fault codes so see what happens if you get her running tomorrow which I'm guessing you will.  :smiley:
Lets hope you don't have a bad fuel pump.
EDIT when we're the glow plugs last replaced?.
maybe a good idea to test them.
Good luck
M
« Last Edit: December 22, 2015, 12:08:05 am by r5gtt »
Offline V3trox
« Reply #24 on: December 22, 2015, 08:26:11 pm »
Easy start got her to splutter back to life :)
but now the bonnet latch has decided its had enough. I sense gremlins....
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #25 on: December 22, 2015, 08:28:32 pm »
Boney catch spring needs greasing  :happy2: mine did that when I bought it  :laugh:
Is it running now???
Offline V3trox
« Reply #26 on: December 22, 2015, 08:33:09 pm »
Yup, just let it idle for a bit. Shut it off and restarted it fine. Tomorrow morning will be the decider :D ten i can flash the map back to it and see if that was a potential problem
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #27 on: December 22, 2015, 08:48:48 pm »
My best friend easy start  :rolleye:
Offline V3trox
« Reply #28 on: December 31, 2015, 03:13:03 pm »
Thought i would post a small update.
Has been fine ever since. Very strange lol
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #29 on: December 31, 2015, 05:00:27 pm »
 :driver: :happy2:
