Author Topic: Service Indicator comes on every month even after being reset.  (Read 1764 times)
Offline dn009757
« on: December 21, 2015, 05:33:13 pm »
Hi,
I have a Mkv Golf gti 2005. The car has been serviced at the correct intervals since being purchased. In the last 2 years the service light continuously comes on. I have been told that there is an oil quality sensor and this could be faulty. Does anyone know what part this sensor is?
Thanks for the help in advance
Offline Flyingscotsman
Re: Service Indicator comes on every month even after being reset.
« Reply #1 on: December 21, 2015, 06:16:36 pm »
I believe that the "oil quality" sensor is simply a temperature sensor, used in conjunction with other ECU data to estimate when oil change is due when set to "long-life" service intervals
Have you tried setting it to 1 year, 10,000 mile fixed service intervals?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #2 on: December 21, 2015, 06:41:20 pm »
Never heard of an oil quality sensor  :laugh:
Have heard of a faulty sensor though  :happy2:
How do you reset the oil sensor?.
« Reply #3 on: December 21, 2015, 08:05:39 pm »
You can reset service interval to fixed. ECU then doesn't try to estimate oil quality.  :smiley:
Offline flashp
  • -Receive: 65
« Reply #4 on: December 22, 2015, 08:18:48 am »
On the VAG platform for the Mk5 the ECU can count the number times the bonnet is opened between servicing. It apparently uses this info to assume an oil level check has taken place.
Gone but not forgotten :-)
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
« Reply #5 on: December 22, 2015, 09:20:03 am »
Get the service interval changed to annual/fixed - problem solved
Offline dn009757
« Reply #6 on: December 23, 2015, 02:53:31 pm »
Thanks!
I guess I will need a VAG COM to change the service interval?
« Reply #7 on: December 24, 2015, 03:44:16 pm »
No. Can be done without VCDS as follows. Turn off ignition. Press & hold trip reset "0.0" button on clocks. Turn on ignition - no need to start car. Release "0.0" button. Press the clock setting minute button "m".  Service interval is now set to 10000 mile/ 1 year.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8 on: December 24, 2015, 03:47:27 pm »
Does anyone know if the service indicator works on mileage as my last oil serve was a year ago now and I've not replaced the oil buy have the parts ready to replace it this weekend.
Only done 3.5k mile in the whole of this year.
« Reply #9 on: December 24, 2015, 04:48:53 pm »
Mileage or time whichever comes first
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10 on: December 24, 2015, 04:54:52 pm »
Thanks Scottymon, so best to service it and reset the service light then.
Will do this it weather permits.
M
