Author Topic: Reverse camera in bumper  (Read 2205 times)
Offline Hannakournikova
« on: December 22, 2015, 07:55:10 pm »
Ok so I know that the official reverse camera for the mk5 and eos is the badge model, but has anyone fitted the number plate light style?
If so what's the viewing image like? Is it too low to the ground?
Offline Takumi
Re: Reverse camera in bumper
« Reply #1 on: December 22, 2015, 09:39:36 pm »
i'm using instead of number plate light. View is very good and helps rear parking at night very much. Image quality would say is same as OEM( maybe depends which one you buy).
Offline Pashka
« Reply #2 on: December 22, 2015, 09:41:57 pm »
I've fitted scirrocco one, it's not on the centre, but for me is fine in all ways.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
Offline skard
  • -Receive: 245
« Reply #3 on: December 22, 2015, 09:53:04 pm »
I had them on my first mk5, well aftermarket ones - they tend to get broken lenses due to the proximity to the ground, the LED's fade, the camera itself creates a shadow on your number plate and finally, some screw into thin air so you need something behind it such as a plastic window frame spacer so when you screw in the camera it goes into the plastic & squeezes down into the bumper to lock it in place.
It's been over three years since I had one, I guess they have improved. For a couple of hours work once a year, I put up with their shortcomings with them being so cheap and effective once fitted.
OEM ones are probably great.
« Reply #4 on: December 23, 2015, 10:17:29 pm »
Amy photos of the image on screen?
Offline Pashka
« Reply #5 on: December 23, 2015, 11:46:50 pm »
I'll do one tommorow.
Offline Bigjimknickers
  • -Given: 55
« Reply #6 on: December 30, 2015, 09:23:34 am »
Has anyone got a link &/or some pics of these bumper cameras fitted? There are so many on eBay it's a mine field knowing what to buy!!
I'm after a number plate one to fit an android head unit.
