Author Topic: stage 2 revo settings ?  (Read 1832 times)
Offline gillm
« on: January 02, 2010, 12:29:11 pm »
hi guys just got a revo select plus off luca (cheers mate) and was wondering what settings i could/should run ?
engine = axx with 30k on it
mods = fmic    turbo back milltek   neuspeed p-flow   forge dv    pcv fix .
west tuned gt28 @ 340hp
Offline vRS Carl
  • -Given: 282
  • -Receive: 240
Re: stage 2 revo settings ?
« Reply #1 on: January 02, 2010, 01:09:47 pm »
I wouldn't run timing so high with fuelling so high straight away.
It's no good really anyone telling you what settings to use as each car is different. You really need to get VCDS before doing anything and then log the Following blocks 115 (boost) 114 (N75 duty cycle) 120 (timing correction factor for each cylinder)
This will then tell you wether or not the settings you are applying is safe. Ideally you don't want to see any more than -3 on the correction side. Up to -5 is acceptable if it's only on one cylinder AND very briefly.
But in essence you NEED to have VCDS or you could do some serious damage.
Carl :happy2:
Offline gillm
« Reply #2 on: January 02, 2010, 06:55:47 pm »
cool i will put vag com on and do some runs . can you talk me threw how to log stuff ?
« Reply #3 on: January 02, 2010, 07:08:22 pm »
Offline Carrera2RS
« Reply #4 on: April 03, 2011, 10:06:11 am »
How did you get on with the select plus ?
I was wondering about one of those. Currently running 6,5,9
