Author Topic: Headlight plug harness  (Read 13339 times)
Offline Vwgtiking
« on: December 22, 2015, 11:32:24 pm »
My clip a are broken and I can only remove the plug by using brute force.
Is there something out where I can plug in this broken harness then plug into the headlight. Then I will never have to touch the broken plug again. Hope this makes sense.
Offline olsen-72
  • -Receive: 21
  • Redditch
Re: Headlight plug harness
« Reply #1 on: December 23, 2015, 12:46:16 am »
You can buy this plug from tps or vw for few quid and re-wire it
STAGING/NEEDLE SWEEP ON ALL WHITE CLOCKS
LIT NEEDLESS, MILES TO EMPTY
GENUINE CAN GATEWAY - SUPPLY AND FIT
CRUISE CONTROL -  SUPPLY AND FIT ALL VW's
CLOCKS CODING - VW SEAT SKODA UP TO 2014
SCIROCCO CLOCKS CONVERSION
Offline Vwgtiking
« Reply #2 on: December 23, 2015, 07:42:25 am »
Is it easy and what tools would I need?
Offline SI-R32
  • -Receive: 126
« Reply #3 on: December 23, 2015, 08:06:43 am »
It's not that easy if you don't normally do these things ,  plus you need a pin removal tool,  so while it can be done it's more for advanced diy'er than a tinkerer
Offline Vwgtiking
« Reply #4 on: December 23, 2015, 08:17:28 am »
Is there an easy way to remove the plug from the headlight other than brute force?
Offline SI-R32
  • -Receive: 126
« Reply #5 on: December 23, 2015, 09:08:42 am »
If the clip/bit you pull on has broken,  the bit that holds the plug in will still be there,  you need to remove an easy plug to get to which has the Same clip,  then work out how the headlight one has broken or will come apart.
Offline SI-R32
  • -Receive: 126
« Reply #6 on: December 23, 2015, 09:11:11 am »
Oh and always push down on a plug before pulling the clip towards the plug,  then pull up,  it allows the clip to unclip a lot easier if the plug is pushed towards the other socket
Offline Vwgtiking
« Reply #7 on: December 23, 2015, 09:23:06 am »
Not sure I understand. There is no clip at all on one of the plugs.
Offline SI-R32
  • -Receive: 126
« Reply #8 on: December 23, 2015, 08:22:25 pm »
Just because the clip head has snapped off don't mean the locking bit has been snapped off,  but if you think it's all defo missing then the headlight ones being at least 10 pins are a little tough to pull apart,  but if it really won't come apart then it must still be locked together
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #9 on: December 23, 2015, 09:10:44 pm »
these plugs have a very painful technique. push the plug in then pull in the clip and watch is slither out  :signLOL: and I'm being serious as working on vag for years.
Offline Vwgtiking
« Reply #10 on: December 23, 2015, 09:20:49 pm »
The locking plastic bit is still present as it locks but the tab to pull is not there so you can move the locking tab thus removing from headlight.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #11 on: December 24, 2015, 05:25:06 pm »
To remove the broken plug from the light, you'll need a pick of some type to poke it through the top and pry the tab up and then release the plug. it's easy enough to do.
M
