Author Topic: Bought a non usb rcd510?!  (Read 1565 times)
Offline Damirz
« on: December 23, 2015, 06:06:43 pm »
So earlier this week an rcd510 came on the market for quite a cheap and I thought I'd grab it till I can afford the rns510.. It arrived today with both the cables to connect the aux and usb. The aux I understand goes into the back of the loom and connects as such but there is no way I can connect then usb? Did a bit of search and found that my one is missing the port to connect the usb to the stereo :sad1: so what I wanna know is if there's a way I can connect up the usb and get it to work?! thanks for any advice on advance!
Offline cenobytez
Re: Bought a non usb rcd510?!
« Reply #1 on: January 04, 2016, 12:20:53 pm »
i thought it was either / or not both?
Offline Pashka
« Reply #2 on: January 04, 2016, 12:35:05 pm »
You bought a RCD510 for asian market yeap? If yes, there is 3 different versions of it. 1 simple, without usb support/camera, with usb support, and with usb/camera support. You can buy MDI unit, to get usb working. If it is for EU market, USB will not work without MDI aswell.
06 1.9 TDI Owner. Retrofits: Bixenons, Drls, Full GT/GTI exterior, RNS510+MDI+Premium Bluetooth+RVC+OPS, Full Fis, MFSW, Cruise control, TPMS, Polar Fis, Boot pop up and more.. :)
Coding, diagnostic and retrofits in Leeds
Pre coded Can Gateways for battery drain issues with RNS510 and similar headunits
Premium Bluetooth modules/kit
RNS510 Service - codes, maps/firmware updates
Latest V8 West EU maps update service for RNS315
