Author Topic: Any skateboarders on here?  (Read 3209 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=a35020gc4go0cpq7eaqk8ptgf3&/topic,90967.msg917089.html#msg917089
« on: December 26, 2015, 03:15:53 pm »
The kids wanted skateboards for christmas so bought a couple from a local sport shop.
They are pants, they don't turn well and one pulls to one side.
Can anyone recommend a good board for 6 year olds? One needs to be girly. I don't mind buying the bits and building my own but have no idea whats what and will probably end up spending way too much.
05 | Tornado Red | DSG
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=a35020gc4go0cpq7eaqk8ptgf3&/topic,19740.0.html
Re: Any skateboarders on here?
« Reply #1 on: December 26, 2015, 03:23:51 pm »
Loosen the trucks. If they are too stiff they wont turn well.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #2 on: December 26, 2015, 03:31:18 pm »
Thanks mate will try it but i think they are just sh*t boards (plastic trucks).
« Reply #3 on: December 26, 2015, 03:32:21 pm »
Pics? Links?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: December 26, 2015, 03:38:51 pm »
The kids picked their own boards. Should have done some research first.
http://www.decathlon.es/skateboard-spiderman-classic-id_8356952.html
http://www.decathlon.es/skateboard-play3-frog-id_8189008.html
They actually looked much better than my first board (which was great).
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: December 26, 2015, 03:42:30 pm »
« Reply #6 on: December 26, 2015, 03:43:49 pm »
Those sohuld be fine for nippers. Are the trucks really stiff??
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #7 on: December 26, 2015, 03:49:59 pm »
I think so will try loosening them before i waste any more money.
Offline Dave(tm)
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89462.0.html
« Reply #8 on: December 26, 2015, 04:43:11 pm »
I know nothing about skateboards. But Decathlon stuff is usually pretty good. Hopefully some tweaking well sort it for them.
Dave
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #9 on: December 26, 2015, 04:49:09 pm »
Dave
I think i enjoyed skateboarding more than them although i'm way to heavy for the kids boards.
I may get myself a board  :evilgrin:   :scared: and see if the kids get on any better with that.
Offline Dave(tm)
« Reply #10 on: December 26, 2015, 04:51:24 pm »
It would be silly to upgrade their boards for them not to get used. Definitely a better option to get yourself a new one for them to try first. Think if ur as protecting your investment.
Offline Pesky jones
« Reply #11 on: December 29, 2015, 08:00:07 pm »
Don't loosen them too much, if it all! Also depending on the trucks there should be one central bolt to loosen, not the corner four bolts. New trucks are always stiff to turn, they take wearing in
« Last Edit: December 29, 2015, 08:01:41 pm by Peskyjones »
Offline WaLLeMs
« Reply #12 on: January 03, 2016, 09:50:31 pm »
In the middle of the trucks is the bolt called a kingpin and that when tight will have super tight hard to turn but make them loose and you can turn as you would on a snow board. There are 2 rubber things called bushings. If they solid rock hard then not matter how loose the trucks are they will steer the way it wants to... I would buy a cheapy but if the kids get into it then proper boards and gear is a must
Sent from my A0001 using Tapatalk
