Author Topic: Edition 30 powered by RBS  (Read 82297 times)
Offline RBS
  • -Receive: 47
Re: Edition 30 powered by RBS
« Reply #135 on: December 22, 2021, 01:14:43 pm »
@LC5F  Thanks for the info👍🏻
The oilpump I ordered has allready the oil presure relieve inside the oilpump and needs NO driling!! Ordered @ MIK Motoren in Germany I looked it up on their site and it looks quality stuff…
Now you’re right about oil & vibration!! More oil is better but vibration means more nock on the pistons also! So it’s a good idea to retune the engine after this setup.
Had a long and very informative conversation with a very nice chap who has a lot of engine nolidge👍🏻
I’ll see how it develops…
Anyway…. It’s good to be back “schraubing” on the vdub :wink:
Offline LC5F
  • -Receive: 80
« Reply #136 on: December 22, 2021, 07:06:00 pm »
@RBS  - Thank you for the information on the kit from MIK Morten https://mikmotoren.de/products/olpumpe-update-ea113?_pos=12&_sid=f5cd350ff&_ss=r
First impression was very expensive, but after watching the you tube video despite having minimal German it seems to be worth the money.
The chain retains the existing TFSI pulley, split chain also means you don't have to remove the timing belt, reduced pulley on the pump changes the oil pressure and the stand off to avoid blocking the oil return is simple but genius!
Offline RBS
  • -Receive: 47
« Reply #137 on: December 22, 2021, 08:53:35 pm »
Exactly what I was thinking :happy2: :wink:
Glad to be helpfull :drinking:
Offline RBS
  • -Receive: 47
« Reply #138 on: December 23, 2021, 03:31:48 pm »
Parts are arriving…
Offline RBS
  • -Receive: 47
« Reply #139 on: December 24, 2021, 02:05:56 pm »
Fuel & cabinfilter also arrived
Offline RBS
  • -Receive: 47
« Reply #140 on: December 27, 2021, 03:55:10 pm »
Also ordered a new DSG filling tube as I could not find my old one :thinking:
It will probably pop up when I’ve finished everything as usual… :doh:
Offline RBS
  • -Receive: 47
« Reply #141 on: January 16, 2022, 12:04:10 pm »
I think it’s time to get into action :confused:
Parts are almost taking over the garage :doh:
I hope I can remember everything…
Offline RBS
  • -Receive: 47
« Reply #142 on: January 20, 2022, 08:22:25 pm »
Went to clean the inlet manifold, inlet valves and injectors today…
Tomorrow… new oil & filter, new spark plugs & DSG oil & filter service :smiley:
« Reply #143 on: January 22, 2022, 11:27:35 am »
Looking good  :happy2:
I saw that video a while ago, and it makes a lot of sense.  The oil pressure gains over the stock unit are impressive.  I don't know how the EA113 even runs with the crappy amount of pressure it dishes out at low rpms.  Having said that, maybe it's not an engine that NEEDS lots of pressure?  Nissan GTR guys who fit uprated oil pumps end up flooding the cylinder head with too much oil.  Hope that isn't the case here.
Offline RBS
  • -Receive: 47
« Reply #144 on: January 22, 2022, 11:32:49 am »
As promised…
Next up today… new spark plugs and cam follower check…. :happy2:
Offline RBS
  • -Receive: 47
« Reply #145 on: January 22, 2022, 11:45:52 am »
@ Pudding
I’ve ordered the kit a while ago… still waiting to receive it :sad1: hope to get it in the following weeks…
I’ll let you guys know more when I get it :happy2:
So far I know, nobody has mounted this kit?? The company MIK Motoren has mounted and sold hundreds of those kits mainly in Germany… Here in Belgium, nobody has it!?
Most kits are from Bartek but they need to be drilled & threded…
I guess I’ll be the mule  :wink: and give my thoughts about it :happy2:
Offline RBS
  • -Receive: 47
« Reply #146 on: January 23, 2022, 08:54:30 pm »
Spark plugs changed…
Old ones still looked good  :happy2:
Camfolower is next…
But family comes first  :drinking:😁
Will do it next weekend👍🏻
Offline RBS
  • -Receive: 47
« Reply #147 on: January 27, 2022, 03:38:25 pm »
Allright  :jumpmove:
Got this delivered today….
All the parts…
Should look something like this when it’s installed…
I’ll keep you guys up to date when I’m installing this oilpump set up…
Next up will be the timingbelt change and the 2 thermostats….
Offline LC5F
  • -Receive: 80
« Reply #148 on: January 27, 2022, 06:06:47 pm »
Potpourri and car parts don't usually mix!
Either your other half is out - or very understanding
I am looking forward to hearing about this kit getting installed.
Also, the tube your oil cap mounts on is able to be removed... to reveal a lower oil cap thread - this is mine ripped off:
Looks so much better.
Offline RBS
  • -Receive: 47
« Reply #149 on: January 27, 2022, 07:48:17 pm »
@LC5F 😁😁 your 1st gues was right :happy2:
And the tube will stay! Have some plans for the engine cover… involves Carbon… but
I’m working on that too 😁
