Author Topic: Edition 30 powered by RBS  (Read 88332 times)
Offline RBS
  • -Receive: 47
Re: Edition 30 powered by RBS
« Reply #30 on: January 19, 2016, 01:23:39 am »
Other VW stuff
Didn't know this was a classic part already :surprised:
That's for now :innocent:
Tune in tomorrow for some other bits :wink:
Offline RBS
  • -Receive: 47
« Reply #31 on: January 19, 2016, 07:43:59 pm »
As promised :
H&R parts
Next up is cleaning the intake and put it on the rollers! We'll see this thursday what it gives completely stock. The moment of truth :signLOL:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #32 on: January 19, 2016, 08:45:55 pm »
Your list of parts is coming along well. :drinking:
Offline RBS
  • -Receive: 47
« Reply #33 on: January 21, 2016, 05:25:38 pm »
 :jumpmove:
It was a great day today!!!! Went to do a intake clean
and a dyno run. Result : on 50.300 KM 237.4 PS! Completely standard, no tuning parts
mounted.
Now I can concentrate on doing an oil change, oilfilter, sparkplugs, cabinfilter, diverter valve + relocation, R8 coils, Forge catch can, new camfollower, DSG oilchange + filter.... Stuff like that! :happy2: Oh AND almost forget : CTS intake + heat shield for now!
Next up will be cambelt change and 034 motorsport engine mounts. First I still got to receive them from the states!  :sad1:
« Last Edit: January 21, 2016, 05:30:34 pm by RBS »
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #34 on: January 21, 2016, 05:30:53 pm »
Nice! :drinking:
Mine needs a to do the diverter valve relocation too. My mechanic only realized that it can be easily done after I picked up my car. :\
Offline RBS
  • -Receive: 47
« Reply #35 on: January 22, 2016, 10:53:45 pm »
Here are finaly some pics from yesterday. There's still more to come but they won't upload for some reason?! Also a couple of short movies. I'll try again tomorrow.
Here ya go:
Intake cleaning:
After intake cleaning:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #36 on: January 22, 2016, 11:39:51 pm »
You have to remove the intake manifold to really clean the intake. :wink:
Offline RBS
  • -Receive: 47
« Reply #37 on: January 23, 2016, 12:23:03 pm »
@ Shoduchi: Yes you're right mate :wink:!
But in my case, the engine was just driven in so it was not nessecery to do this. Only if cars have 100.000KM or more it is better to remove the intake completely. Then it is a more efficient cleaning.
Now back to bussines  :drinking:
Received a couple of new packages: :jumpmove:
Now only a couple of packages left! Finaly
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #38 on: January 23, 2016, 12:48:30 pm »
Since your mechanic will have to take the front of your Ed. 30 to fit the IC, it's not that hard to do the intake cleaning. With the front out is much easier to replace the fuel pressure return valve too.
Look at mine with 57.000 km:
My mechanic and I weren't expecting that it was this bad with so few km... :sad1:
It made 243 BHP with all that gunk in the valve stems...
I'd also recommend replacing all thermostats (your car has 2) and temperature sensors (I think you have 2 as well) because they're not that expensive parts, are prone to malfunction and it's the labour to replace them that can be a PITA.
DSG   thermostat: 4E0121113
Engine thermostat: 06F121111H
Engine thermostat seal: 06B121119B
Temp sensor: 2x 06A919501A
Temp seal: 2x N90316802
Retention clip: 2x 32121142
Your build is awesome! :notworthy:
Offline RBS
  • -Receive: 47
« Reply #39 on: January 23, 2016, 01:00:04 pm »
@Shoduchi:surprised: WOW! That's a lot of debrie! For only 57.000KM!?!
Ok I'll check it again when I'm instaling the intercooler and hoses, the front is than out anyway!
And thanks again for the info about changing thermostats & sensors! :happy2: Will order them and replace them!
Oh and I forgot to put proof of the Dyno run! Here it is :
Thanks again mate :wink:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #40 on: January 23, 2016, 01:03:16 pm »
Just trying to help a fellow Ed. 30 owner! :happy2:
Offline RBS
  • -Receive: 47
« Reply #41 on: January 23, 2016, 01:04:36 pm »
It is me who should be  :notworthy: :notworthy: doing this! :drinking:
Offline RBS
  • -Receive: 47
« Reply #42 on: January 26, 2016, 02:54:41 pm »
Just some shots :smiley:
Offline RBS
  • -Receive: 47
« Reply #43 on: February 10, 2016, 04:10:19 pm »
Hi guys :wink: it's been a while!!
I've been very bussy these last weeks and haden't much time to bring an update :ashamed:
I've changed the engine oil and filter aswel as the DSG gearbox oil and filter. Also new sparkplugs, new CTS Turbo intake filter. Removed the noise conductor and put the Forge catch can! Next up will be the camfollower!
Pic's will follow this evening! :wink:
Offline RBS
  • -Receive: 47
« Reply #44 on: February 10, 2016, 10:00:56 pm »
As promised:
virgin standard
Then the transformation :wink:
And finaly the end result
