Author Topic: Breathing mods  (Read 1510 times)
Offline MarkyN
    • www.instagram.com/marky_n
Breathing mods
« on: December 31, 2015, 03:38:42 pm »
I have read that the standard breather systems on the GTi's are not the best and when going into tuning the engine up I have been led to believe that changing it to the breather system of the R line (I Think) is a good upgrade and will help the engine more
Has anyone heard of this? Or has anyone done it?
I have noticed blanking plates by the like of Forge etc but they need a oil catch tank fitting to I believe?
The breather system OEM number I have been given is
Breather System R - 06F129101R
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
Re: Breathing mods
« Reply #1 on: December 31, 2015, 04:57:03 pm »
PCV delete from R-Tech is the only true full PCV delete that works.
#1493
Offline Dan_FR
  • -Given: 132
  • -Receive: 189
  • wait...what?
Re: Breathing mods
« Reply #2 on: December 31, 2015, 05:34:14 pm »
The R is just the latest revision of the original PCV valve, its more reliable than the older original variation. Only needs doing if your PCV is faulty or worth doing as preventative maintenance.
Stay away from PCV deletes though unless you go for thr RTech kit
