Author Topic: Centre caps  (Read 2056 times)
Offline Vwgtiking
Centre caps
« on: January 01, 2016, 11:33:00 am »
Am after VW centre caps for my ch reps. Having measure mine the face needs to be anything from 65-68mm and clip 62mm. I can't find any with the clip size I require.
Anyone know of any or links on eBay?
Offline doylebros
Offline Vwgtiking
Re: Centre caps
« Reply #2 on: January 01, 2016, 01:15:06 pm »
I seen them but the clip size is only 56mm I need 62mm
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Centre caps
« Reply #3 on: January 01, 2016, 07:32:25 pm »
Those ebay ones discolour as ive had a set and the seller promised a replacement set foc but never delivered. :mad:
Offline Vwgtiking
Re: Centre caps
« Reply #4 on: January 01, 2016, 10:32:12 pm »
There's no where else to get them for the size I require.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Centre caps
« Reply #5 on: January 01, 2016, 10:37:55 pm »
They have the measurements wrong as if you look at them. They are 65 mm across the top and 62 mm internal clip. as I said I've bought these cheap cr** and only fitted three on in January 2014 and may 2014 come they have faded and the black turned grey. I've now lacquered the last one and will see how long this takes to discolour if at all as the lacquer cote may save it.
« Last Edit: January 01, 2016, 10:46:27 pm by r5gtt »
Offline Vwgtiking
Re: Centre caps
« Reply #6 on: January 02, 2016, 09:00:02 am »
How you know they are wrong?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Centre caps
« Reply #7 on: January 02, 2016, 03:15:18 pm »
look at the picture and you can see that the whole cap is 65 mm and the clips are a few mm in. message the seller for reassurance.
Offline Vwgtiking
Re: Centre caps
« Reply #8 on: January 02, 2016, 04:37:36 pm »
I know what you mean I see loads of them like that and generally picture is just for illustration.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: Centre caps
« Reply #9 on: January 02, 2016, 04:57:31 pm »
Yes don't be frightened and make sure you buy a can of lacquer and do as I did as they are cheap for a reason  :happy2:
