Author Topic: R5GTT'S Cars rapid  (Read 257261 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: R5GTT'S Soon to be K04'd beast
« Reply #615 on: December 01, 2016, 10:58:29 am »
Not everybody's car pops the bootlid when you hold the button down on the fob...... mine didn't as standard - just allowed you to open the boot using the handle whilst keeping the doors locked
Thats correct my bad  :doh: the programming must release the stricter from the lock in order to use the pop up function hence needing vagcom to do this.
Thanks @Dan_FR  :drinking:
Offline Paradox1
  • -Given: 41
« Reply #616 on: December 01, 2016, 11:02:53 am »
Have you got everything you need for your brakes now?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #617 on: December 01, 2016, 11:04:20 am »
I may need the wear sensor but stuck as to what to buy as the Porsche one worn fit the golf will it?.
Offline Paradox1
  • -Given: 41
« Reply #618 on: December 01, 2016, 11:24:32 am »
Just code it out. You dont need a sensor to tell you when your brakes are low
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #619 on: December 01, 2016, 11:32:58 am »
I've already coded it out  :signLOL:
Offline Paradox1
  • -Given: 41
« Reply #620 on: December 01, 2016, 11:42:53 am »
So what you waiting for then lol :grin:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #621 on: December 01, 2016, 03:09:32 pm »
waiting for someone to sandblast the calipers as the other guy has F them up  :fighting: barstool
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #622 on: December 02, 2016, 02:51:43 pm »
Finally have the led's rings in but need to get the drill to pass wires through the back.
Need help on this please mate, could I get away with using 70mm halo? Also what do you wire this up to?
 :drinking:
Hello mate, you will need 90mm rings as 70mm ones won't sit around the inner chrome section. See my build thread here http://www.mk5golfgti.co.uk/forum/index.php/topic,103299.105.html  :happy2:
« Last Edit: December 02, 2016, 03:03:08 pm by r5gtt »
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #623 on: December 02, 2016, 02:52:06 pm »
FOLDING PUDDLE LIGHTS WITH BLACK INDICATOR LENSES SOON TO GO ON  :smiley:
ONE WITH AND ONE WITHOUT BLACK INDICATOR LENSE
BOTH WITH BLACK LENSES
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #624 on: December 02, 2016, 02:58:51 pm »
NEW DEPO XENONS ARRIVED IN 3 DAYS FROM GERMANY  :grin:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #625 on: December 02, 2016, 03:06:02 pm »
What sort of total cost are you looking at with HIDs mate? I'm umming and ahhing between these and oem xenons; not too sure which path to take. And am I right in saying you can get Depos with black innards (like standard GTI lights) whereas oem xenons are 'plain'?
Edit... these look dark now I've had a proper look at the photo. Or am I imagining it?!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #626 on: December 02, 2016, 03:11:42 pm »
Ive just paid £200 for the lights them selves where as my last set I bough used for £100 and the hid kit cost me £20 but I'd recommend a decent set on hid lights as the cheaper ones seem to fade in power output real quick!. I wanted oem but was let down a few times so thought F you all and bought this set as it's way cheaper to go depo and yes they have black inners where as the oem are chrome  :sick: I'm actually happy I bought these again as I had no complaints with the previous set I have on the car apart from one is now broken due to the non fault I had.  :happy2: so I'd recommend these after market ones to you and I'm surprised you've not done this ages ago  :surprised:
« Last Edit: January 30, 2017, 01:33:16 pm by r5gtt »
Offline v4rley
  • -Receive: 104
« Reply #627 on: December 02, 2016, 03:12:31 pm »
You put led units in the puddle light whilst you had them stripped down?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #628 on: December 02, 2016, 03:18:19 pm »
Ive just paid £200 for the lights them selves where as my last set I bough used for £100 and the hid kit cost me £20 but I'd recommend a decent set on his lights as the cheaper ones seem to fade in power output real quick!. I wanted oem but was let down a few times so thought F you all and bought this set as it's way cheaper to go depo and yes they have black inners where as the oem are chrome  :sick: I'm actually happy I bought these again as I had no complaints with the previous set I have on the car apart from one is now broken due to the non fault I had.  :happy2: so I'd recommend these after market ones to you and I'm surprised you've not done this ages ago  :surprised:
Cheers for the info. Yeah it's always been firmly on the list, I've just prioritised other stuff up to now. The next few mods will be cosmetic stuff like this and hopefully a decent headunit etc. Then I'm going to take a gamble on coilovers and ARBs (I don't want to ruin the ride) along with an anti-lift kit... basically as much as I can do to help in getting the power to the road, before I turn my attention to the turbo.
I'll probably need a bit of advice regarding HIDs etc when I get round to it...!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #629 on: December 02, 2016, 03:21:41 pm »
oh don't start me off  :doh: I haven't fitted leds on as I was worried about the error lights coming on and I'd rather not have to deal with that unless someone can tell me otherwise so I can go spend the last few pennies I have left  :signLOL:
