Author Topic: R5GTT'S Cars rapid  (Read 273426 times)
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: R5GTT'S Staying K03 as I've changed my mind
« Reply #750 on: January 20, 2017, 07:41:59 pm »
Just seen your k04 comment mate. I reckon you should just bite the bullet and fit a k04 while it's all in bits. You know you're going to want a k04 soon after going 2+ on the k03!
yeah you're most likely right about that but I'm going to need to source another K04 so going to wait a while tbh.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #751 on: January 20, 2017, 07:42:36 pm »
I know, but the S3 IC would be the ideal IC for a K03 stage 2+... You'll get lag that I bet you won't like much... :signLOL:
Got to agree with this, assuming it's in addition to your OEM cooler, @r5gtt ?
An OEM replacement like a Peron or Airtec Stage 2 you could probably run without any detrimental pressure drop. But on a k03, two coolers, and all that volume to fill, it's got to be pushing it a bit. There's only so much air a k03 can move.
Actually that's got me thinking laterally about a way round this. Could you get rid of the OEM cooler and reroute the pipework so that you're just running this front mount? Assuming this on its own would do a comparable job to an S3 cooler on its own, albeit in different locations.
Moving it in front of the rad in itself should see benefit in terms of heat exchange. But there must be some logic in VW designing the layout as they have.
I was never going to use two coolers buddy  :surprised: my minds set to fit the FMIC stand alone and get the car mapped to st2+ and then get another K04 and then fit that in when the warmer days come along. Seriously shouldn't have sold that K04  :doh: don't think I'll find one in as good a condition as that one.
Moving it to the front will definitely help with lowering temps and hopefully with the power I'll be running it'll not give me any lag but pre map I'll be lagging all over the place
Ahhh, I get you. I was thinking this was along the lines of a Twintercooler - retaining the OEM cooler.
So it's essentially a Wellycooler?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #752 on: January 20, 2017, 07:44:35 pm »
Yeah, just get the K04 fitted and be done with it! :evilgrin:
:signLOL:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #753 on: January 20, 2017, 07:49:23 pm »
yes that's right it's a welly cooler.  :happy2:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #754 on: January 20, 2017, 07:51:22 pm »
You'll be fine with that then. Maybe a tiny bit of pressure drop but it shouldn't be enough to cause any really noticeable lag.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #755 on: January 20, 2017, 07:59:45 pm »
yeah I wouldn't have thought it would as many gti owners are or have fitted them to st2 + cars so can't be a bad thing.
I can't believe you thought I'd be doubling it up with my oem one :signLOL:
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #756 on: January 20, 2017, 08:02:32 pm »
I never read threads properly!
Make sure you do a little write up of the fitting. I might follow suit if there's not too much 'custom fabrication' involved...
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #757 on: January 20, 2017, 11:37:01 pm »
Read the flipping thread  :doh: the write up part will be a pain as it's a lengthy fabrication process when doing out on the road so to speak  :sad1:
Will see what happens in any case.
Offline v4rley
  • -Receive: 104
« Reply #758 on: January 23, 2017, 04:03:17 pm »
Wow! Never seen the front panel removed to do that job  :thinking:
Wouldn't it have been easier and more beneficial to remove the inlet manifold and have done the valves therefore achieving 3 jobs  :P
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #759 on: January 23, 2017, 04:14:28 pm »
I removed it to replace the broken front panel dude  :doh:
Let me tell you that it's a beech to replace this and to take the inlet off it's another pain in the ass.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
Re: R5GTT'S Donno know what im doing but it's gonna be good
« Reply #760 on: February 02, 2017, 07:42:46 pm »
Devils own wmi has arrived but need a boost switch for it  :thinking:
Offline Paradox1
  • -Given: 41
« Reply #761 on: February 03, 2017, 11:51:49 am »
1 - 50+ pages and still no remap
2-  I'll get the boost switch and Silicone for you.
Keep it up girl pants
Offline Pesky jones
« Reply #762 on: February 03, 2017, 12:25:33 pm »
 :signLOL:  In fairness he is getting everything ready. And then selling all the hardware. And then getting it ready again
It'll be May before he gets seen to at r-tech as well, 100 pages by then.
 :wink:
Offline Paradox1
  • -Given: 41
« Reply #763 on: February 03, 2017, 12:33:43 pm »
 :wink:
You mean may 2018 lol
He buys 80% of mods he needs.... then decides he shouldnt have brought everything in a bulk. then sells it. then a week later tries to look for another one to buy.
Hard life bless him  :grin: :grin:
Offline Pesky jones
« Reply #764 on: February 03, 2017, 01:15:53 pm »
haha poor r5. Will be worth it if when it gets done
I spoke to Ben yesterday for k04 conversion mapping and he said not until may - I assumed he meant this year haha
