Author Topic: R5GTT'S Cars rapid  (Read 259697 times)
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: R5GTT'S Donno know what im doing but it's gonna be good
« Reply #840 on: March 08, 2017, 10:22:50 pm »
Did you mod your TT like this as well?
Sent from my SM-G928F using Tapatalk
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #841 on: March 09, 2017, 12:28:07 am »
Ah I see - I thought all this time it was a non runner still as you were putting pics of random parts didn't think it was all on the car now  :happy2:
what I do is gather the parts and when I have the time/weather is good and my hand and arm aren't aching so bad I do what I can. Car is never off road as it's not possible where I live.
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #842 on: March 09, 2017, 12:28:37 am »
yeah
Offline Pesky jones
« Reply #843 on: March 27, 2017, 08:42:13 am »
Unlucky with the bolt, I recently had the same with one of the anti roll bar bracket bolts. What is your jack supporting in the first pic?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #844 on: March 27, 2017, 10:46:58 am »
Only with a vag mate  :doh:
It was supporting the gearbox up as the front wishbone bolt doesn't have full clearance.
Offline Pesky jones
« Reply #845 on: March 27, 2017, 11:39:39 am »
So you couldn't get the passenger side wishbone out without lifting the gearbox slightly? Did you loosen any of the mounts before jacking it up or just kept them as they were and raised it slightly?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #846 on: March 27, 2017, 11:53:00 am »
Gearbox bolts x4 out to get clearance as I did try to do it without taking th bolts out but the box wouldn't raise high enough to get the bolt out as it's a very long bolt too
Offline Pesky jones
« Reply #847 on: March 27, 2017, 12:29:08 pm »
Strange, I haven't seen anyone need to raise the gearbox to remove the wishbone unless im missing something. Thought it was just three ball joint bolts, front bush bolt, then the three rear bushing bolts to drop the rear bush console and the whole thing will just drop down
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #848 on: March 27, 2017, 12:53:01 pm »
Unless I was doing something wrong the bolts too long to come out for the front wishbone bush and definitely won't clear the gearbox as that didn't lift high enough when I jacked it up. Mine is dsg so could be because it's a longer box
Offline Pesky jones
« Reply #849 on: March 27, 2017, 01:15:18 pm »
Ah I see. Strange one - see what happens when I do mine
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #850 on: March 27, 2017, 01:16:26 pm »
I didn't think it was going to be an issue but looks like it is  :doh:
Offline mkmg76
« Reply #851 on: March 30, 2017, 03:17:30 pm »
Just spent the last 2 days in work reading this from front to back between calls etc..............what a thread! Glad it's starting to come together for you, keep it up.  :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #852 on: March 30, 2017, 04:06:00 pm »
thanks @mkmg76 it's a very long thread with some nonsensical poop added by some but glad you enjoyed it and hopefully get it to full spec this year  :signLOL:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #853 on: April 03, 2017, 09:05:35 am »
Much work on the puddle lights?
Just replaced a full wing mirror yesterday and figured I nearly should have done the puddle light mod while I was at it.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #854 on: April 03, 2017, 09:10:46 am »
Good work there r5gtt! You must like it a lot more now on hard cornering. :drinking:
